World Lines Problem, axes as meters
  • Thread starter Thread starter The_Doukem
    Axes Lines
The discussion focuses on solving a physics homework problem involving metric distances between pairs of events represented on a graph with axes measured in meters. For part a, the solution involved calculating spatial distances by subtracting values on the x-axis. Part b required determining causality by drawing causality lines, which was deemed easier. The initial confusion stemmed from the unconventional use of meters for both spatial and temporal axes. Overall, the solutions for both parts were confirmed as correct.
The_Doukem
4) In the above figure, the horizontal axis is x measures in meters, the vertical axis is t measured in meters (SR units!)
a) For the pairs of events AB, AC, CB, determine the metric distance between them.
b) For each pair answer whether the first member of the pair could have caused the second member.
See attachment for graph.
3. The Attempt at a Solution [/b
As the axes are in meters the problem was instantly confusing.
For part a) we assumed spatial distance, so we subtracted distances on the x-axis and found our solution that way.
part b) was easier, we just drew in the causality lines and determined the solution that way.
I assume you're looking for this to be checked?
Part A is correct and Part B looks OK to me.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
