Yo guys how do i graph acceleration
To graph the acceleration of the Lotus Elise from 0 to 100 km/h in 5 seconds, it is suggested to plot velocity versus time on the graph. The x-axis should represent time, while the y-axis should represent velocity. Since the nature of the acceleration is not specified, various graph shapes are possible depending on whether the acceleration is constant or variable. Clarification on the type of acceleration would help determine the exact graph shape. Overall, without additional details, the most straightforward approach is to graph velocity against time.
aaquib
Question 1. The Lotus Elise is capable of accelerating from 0 to 100km/h in 5 seconds. Graph
HOW DO I GRAPH? WHAT DO I PUT ON MY X AND Y AXIS??
Graph what? Position? Acceleration? Velocity? Jerk?
If that's all the information you are given, I would assume that they want you to graph velocity vs. time. However, because it doesn't state the nature of the acceleration there are many possibilities for the actual shape of the graph.
Poor question.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
