Young modulus diameter question
The discussion revolves around calculating the diameter of a steel cable needed to suspend a 1200 kg passenger lift. The stress on the cable is given as 1100 MN/m², and the force is calculated using F = m x g, where g is approximated to 10 m/s². The user attempts to find the area of the cable using the formula A = F/σ but struggles with unit conversions. Clarification is provided regarding the relationship between mass and force, emphasizing the need to use the correct gravitational constant. Ultimately, the user is guided to correctly calculate the diameter based on the area derived from the stress and force.
steb4242
I have started a home study course in mechanical engineering, I now realize that I should have started with a math’s course but any way I have a question that I could do with some help with. A designer wishes to calculate the thickness (diameter) of a steel cable for suspending a passenger lift.
mass=1200kg
σ=1100 MN ¯²
g=10 ms¯²
Hi steb4242, welcome to PF. What does the symbol σ represent? What is the load on the cable? How about the stress?
Hi I have the formula for stress which is σ=F/A the figure given for that is 1100MN m¯² and the force which is 1200kg x 10ms¯² as the formula F= m x g
when i rearange the formula to A=F/σ A=12000Nms¯²/1100MN m¯²
i then get a bit lost as what to with the units to get a figure for the area
if i can get the area of the steel rope i can rearange the formula πr² r=√area/π
am i totally off the mark?
This is fine. What is the relationship between N and kg m s-2?
hi using 1kg=9.8N i have worked out a figure to 11.67 but i am not sure about the units
σ=12000kgms¯² x 9.8 = 117600 Nms¯²
σ=F/A rearranged A=F/σ
A=117600Nms¯²/1100NM m¯²
A=106.9
πr²=106.9 rearranged r = A/π then √answer
106.9/π =34.03
√34.03 = 5.83
r=5.83 x 2 =11.67
diameter = 11.67
steb4242 said:
1kg=9.8N
Not quite. A mass of 1 kg corresponds to a downward force of 9.8 N in a gravitational field of 9.8 m s-2 downward acceleration, because F=ma and 1 N = 1 kg m s-2. But here you're given a gravitational field of 10 m s-2. Know what I mean?
