What is the Young's modulus of this iron alloy wire?
The discussion revolves around calculating Young's modulus for an iron alloy wire subjected to a 66 kg mass, which causes a stretch of 1.12 cm. The formula for Young's modulus is provided, and there is clarification that the force (F) should be based on the weight of the hanging mass rather than the mass of a mole of iron. Participants emphasize that Young's modulus is a material property, independent of the total mass or geometry in ideal cases, although the mass can have an indirect effect. The negligible mass of the wire compared to the hanging load is noted, but larger wire masses could influence the calculation. Ultimately, the focus remains on accurately determining Young's modulus based on the applied load and the wire's dimensions.
magma_saber
A hanging wire made of an alloy of iron with diameter 0.09 cm is initially 2.2 m long. When a 66 kg mass is hung from it, the wire stretches an amount 1.12 cm. A mole of iron has a mass of 56 grams, and its density is 7.87 g/cm3.
Based on these experimental measurements, what is Young's modulus for this alloy of iron?
Y = \frac{F/A}{dL/L}
What is F? Is it the mass of one mole times gravity?
F = 0.056kg x 9.8 m/s2
A = 2.54e-6
dL = 0.0112
L = 2.2
A = 2.54e-6
dL = 0.0112
L = 2.2
Don't worry about the mole...concern yourself with the weight of the hanging mass.
Or alternatively, here's a sample of certain dimensions, here's an applied load, here's the change in length, the sky is blue and I had a sandwich for lunch. A popular technique to distract you and see if you understand what you're doing is to throw in extraneous information.
isn't young's modulus not dependent of the total mass? isn't it just based on the type of material such as iron. so it doesn't matter if the total mass is 100 kg or 1 kg, they should have the same young's modulus.
The mole is a useless bit of information. Youngs modulus is a material property so therefore not dependant directly on the mass or geometry for ideal cases.
It is important to note that the mass does have an effect indirectly.
In the original question: the mass of the bar is about 12g (worked this out in my head so check it). This compared to the 66Kg load is insignificant so the mass of the bar can be ignored.
However if the bar were very large (100kg) then this is obviously more significant than the load mass (66kg) so then the mass of the bar becomes important.
