LM741
- 130
do you guys aggree with this:
The zero state response is never affected by initial conditions.
thanks
thanks
Do you really understand what zero state response means? By definition, ZSR is the response of the system when all initial conditions are zero. How can you calculate ZSR with varying initial conditions?LM741 said:what i mean by affected is: you will always get the same answer for sero state response regardless of what the initial condition are. i.e. there is no correlation.
thanks
Zero State Response refers to the natural response of a system when it is at equilibrium or its initial state. It is the output of a system when there are no external inputs or disturbances present.
Zero State Response can be calculated using the transfer function of a system and the initial conditions. It involves solving a differential equation that represents the system's behavior without any external input.
Zero State Response helps in understanding the behavior of a system in its initial state or at equilibrium. It also provides insights into how the system will respond to external inputs and disturbances.
The initial conditions of a system, such as its initial position, velocity, and acceleration, can affect its Zero State Response. The type of system and its transfer function also play a crucial role in determining the Zero State Response.
Zero State Response is essential in applications such as control systems, signal processing, and circuit analysis. It helps in predicting the behavior of a system and designing systems with desired response characteristics.
