ZnO nanoparticles do not sediment properly in centrifuge?
  • Thread starter Thread starter goggles31
    Centrifuge
The discussion revolves around the centrifugation of a sample at 9000 rpm for 30 minutes, resulting in sediment that detaches when the centrifuge is tilted. Key points include inquiries about the viscosity and type of liquid used in the tube, as well as the nature of the particles, with a caution against the misuse of the term "nanoparticles." The conversation highlights potential electrostatic issues and the importance of the solvent's quality in precipitating nanoparticles. If the particles are too small or if the solvent is not sufficiently poor, precipitation may fail. Loose precipitate suggests the presence of other compounds that may hinder the formation of a tighter pellet, prompting considerations of how these compounds interact with the solvents involved.
goggles31
I centrifuged my sample at 9000 rpm for 30 minutes. There is a layer of sediment on the wall but if i tilt the centrifuge it comes off the wall.
Chemistry news on Phys.org
For starters:
What is the viscosity of the liquid? And what liquid is in the tube?
... assuming they truly are nanoparticles - because people have been misusing that word a lot.
There can be electrostatic problems for example.
Someone here may know the standard procedure for this separation.
can you give me the name of liquid?
Are you trying to precipitate your nanoparticles by injecting a poorer solvent? If that's the case, there could be a few reasons why this is not working. If the particles are too small, then even if they are in a poor solvent they may not precipitate. If the solvent is not bad enough, that will also cause this. In my experience, loose precipitate generally means that there is other "stuff" in there that is keeping the particles from forming a tighter pellet. Think about what other compounds there are and how they will interact with the solvent(s).
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
