Please help transistor amplifier
In summary: So, if you choose Ie=1mA, you only have 25Ω to play with, which means you want rl to be very large value, which means you want to use a Darlington transistor.In summary, if you want to design a CE amplifier with a gain of 50, you can use two stages, each with a gain of x10 and x5 respectively. Alternatively, you can use one stage with a gain of 50, but it may be more difficult to design and may not be as reliable. It is important to consider the input and output impedances of the circuit in order to achieve the desired voltage gain.
  • #176
michael1978 said:
why don't become plus + in place from minus - like this re1||re2 (re1*re2)/(re1+re2)
This expression has re2 on both sides. We need to extract it to one side, and if you do the algebra you will see how the - sign comes about.
re2 = ( 220 * 11.5 ) / (220 - 11.5) = 12.13 ⋍ 12
  • #177
NascentOxygen said:
In my post, the -12.5 is crossed out. It's replaced by -11.5.
yes i know but i ask somthing else
look this
re2 = ( 220 * 11.5 ) / (220 - 11.5) = 12.13 ⋍ 12Ω.
, of this is other formula
can you answer me
  • #178
yes you right i am learning a little bit math , from the book basic math for electronics
is not the same like this equation
  • #179
Jony130 said:
When we start design any circuit we need to know circuit specification.
If you have a 2mV input voltage and 100mV at output you need a amplifier with gain
Av = 100mV/2mV = 50[V/V] and Zin = 50K and Rload >2K.
Is not so easy to meet all this requirements whit this simple amplifier.
So I change them to
Voltage Gain= 50
Load Resistance= 10k ohm
Vce= 5V
First we need select BJT I choose BC546C with typical hfe = 520 and Hfe_min = 420
I start selection from Rc resistor.
Rc < 0.1Rload = 1KΩ
Additional I assume Ve = 1V
So
Ic = (Vcc - Vce - Ve)/Rc = (10V - 5V - 1V)/1KΩ = 4mA
next
Re1 = Ve/Ic = 1V/4mA = 250 but I chose 220Ω
Vb = Ic*RE + Vbe = 4mA * 220Ω + 0.65V = 1.53V (voltage at base)
Ib = Ic/Hfe_min = 4mA/420 ≈ 10μA (base current)
R2 = Vb / ( 5 * Ib) = 30K
R1 = ( Vcc - Vb) / ( 6 * Ib) = 150KΩ
So know if we want voltage gain 50V/V
Av = 50 = (Rc|| RL) / ( re + (Re1||Re2) )
( re + (Re1||Re2) ) = (Rc|| RL) / 70 = 909Ω/50 = 18Ω
re = 26mV/Ic = 26mV/4mA = 6.5Ω
18Ω = (re + (Re1||Re2)) = ( 6.5Ω + (220||Re2) )
Re1||Re2 = 18Ω - re = 11.5Ω
Re2 = ( 220 * 11.5 ) / (220 - 12.5) = 12.1 = 12Ω.
And now we have a circuit that we can change gain quite easily.
From
Rc/Re1 = 1K/220 = 4.5[V/V] if we remove Re2 and C2
to
Rc/re = 1K/6.5 = 153[V/V] if we short Re1.And normally to meet all your requirements we need to use more practical amplifier circuit or op amp.
JONEY why i get 0.200 Vac?,
  • #180
I don't know why. Maybe you made a mistake in simulation program.
  • #181
yes Jony, i do it one more time and is now 0,68 Vac now smaller, of i have to change the emitter capacitor , because the value of capacitor i make 1000u, of transistor , which transistor you think to use do you know some type?
because input is 2mv*50gain=100MV
thnx for reply
  • #182
The BC109C is a popular high gain general purpose transistor.
  • #183
i will change now
i don't have that type of transistor
  • #184
look my circuit, i don't know where i make mistake, normal gain have to be 50*2Mv=100mV Peak
  • #185
It's not a very good design. For bias point stability (against VB and ß variations) you should allow a couple of volts across the emitter resistor; you have just 0.4V.
For maximum symmetrical output swing, you should allow approx as much voltage across RC as VCE. But you have ~1.8V and 7.8V, resp.
At what frequency are you measuring the ac gain?
  • #186
No the design is good. Simply the BJT that michael1978 use in his simulation has a very low current gain.
Ie = 0.4V/220Ω = 1.8mA
And Ib = IR4 - IR5
IR4 = 1V/30K = 33.4μA
IR5 = (10V - 1V)/150kΩ = 9V/150KΩ = 60μA
So Ib = 60μA - 33.4μA = 26.6μA
And Hfe = β = (Ie/Ib - 1) = 66.6
And this circuit was design for Hfe > 420
  • #187
at 20kh
thnx for reply
  • #188
And Ib = IR4 - IR5
so result is correct 66.6, for ib like this is formula for current Ir5-Ir4? is not the same for ir4 and ir5 they are in serie ir4 and ir5
but Jony you told Ve to be 1v why is now Ve 0.4V?
thnx for reply
  • #189
michael1978 said:
so result is correct 66.6, or voltage gain is 66.6, if so 66.6*2Mv=133mv again the result is not corrcect
thnx for reply
thnx for reply
]so result is correct 66.6, or voltage gain is 66.6, if so 66.6*2Mv=133mv again the result is not corrcect
thnx for reply[/QUOTE]
thnx for reply
  • #190
michael1978 said:
thnx for reply
thnx for reply
hi Jony, can you answer me please
  • #191
michael1978 said:
thnx for reply
thnx for reply
66 is a BJT current gain, not a amplifier voltage gain.
So in order to make this circuit work properly. You need change the BJT that you use in your simulation program. You need to find the BJT with Hfe > 300 in your simulation.
  • #192
ah 66 is current gain, so you mean to change type of transistor, but is possible for you to tell me any type of transistor which work, because there are a lot of type of transistor, and somebody he tell me one type of transistor but that transistor don't exist in my list of transistors
and yes Jony if you can tell me, i try to find self soms but i can't find it, that is the problem
thnx for reply
  • #193
BC548C
What simulation program do yo use ?
  • #194
Jony130 said:
BC548C
o joney i don't have, i have bc548A but not BC548C, i use B2 Spice A/V
  • #195
hey Jony i try with bc548A, and i get voltage gain of 84mv is this correct?
  • #196
Use BC547C
  • #197
Jony130 said:
Use BC547C
yes Joney i have that type i change, and now voltage gain is 94mv is correct now?
  • #198
Well first you need to learn how to use the simulation program.
I use B2 Spice V5 and as a BJT use BC547C. And AC sweep analysis show that voltage gain is equal to 50.1V/V
For 20mV at input I get 1V at output.
  • #199
but this was disegn for 10v battery not 12v
  • #200
Well for Vcc = 10V the voltage gain is equal to 46V/V (0.9V at output for 20mV at input) because we don't included RL in our calculations when we solve for Re2.
  • #201
my circuit look like this
  • #202
If so, your voltage gain is equal to 46V/V
  • #203
my circuit look like this , the voltage gain is correct almost the same like yours, but metter gain is not correct, WHY GAIN METTER NOT CORRECT
  • #204
yes almost 2Mv*46=92MV my 94MV
  • #205
So everything is OK
  • #206
Jony130 said:
So everything is OK
yes now, but can you tell me jony how to find in transistore HFE
because when you design this circuit
first you say
and after
how me to find me Hfe, you know which software i use
thnx for help
  • #207
happy christmas to everybody,
jony can you help me for Hfe, i have to look in datasheet of i can look also in B2 spice?
  • #208
You can use your simulation program to find Hfe or datasheet it's up to you.
  • #209
so i have self to look in datasheet for transistor, because my simulator he tell me maximum of hfe but not a minimum of hfe
thnx for reply
  • #210
You should run your simulation a number of times, testing that it works satisfactorily with hfemax and hfemin, and (for multi-transistor circuits) all combinations.
  • Electrical Engineering
