Herman Trivilino
- 1,739
Can't tell from photo. Can you see it from inside the attic? Does it come straight up through the wall below.sevensages said:Do you agree with me that that plastic pipe coming out of my roof is my stack?
If you can determine where the stack rises into the attic through a wall top plate, look to see if that is a plumbing wall. Look inside the house at that wall and see if it's wider than a 2x4. If so, it could be a plumbing wall. Especially if that wall is behind a toilet.
sevensages said:Please look at the photographs I posted on post #17. Notice that my concrete patio is directly below my stack. So I cannot poke around directly below my stack with a shovel because that area is concrete.
Is there a toilet directly under that pipe coming up through the roof?
These are signs that your clean out is beneath that slab. It's tempting to saw a hole in that slab. Plumbers have a tool they use to locate buried sewer lines but unfortunately they aren't very precise. I would hate to cut a hole in the slab only to find out the pipe is only close to the hole. But if that is your only option, then you have to probe the soil under the slab through that hole, and widen the hole. That's if you get lucky.
If all that sounds too much, and I think it does, I would try to get a plumber to find where the pipe is buried next to that slab, dig to uncover it, and install a new clean out there.
I live in the Houston area so our climate doesn't require pipes to be buried very deep. Code requires clean outs be no further than 100 ft from the manhole. Mine is 120 ft. We had a blockage within 20 ft of the manhole due to tree roots that had been an issue for 20 years. We dug it out and found that pipe (thin wall) was broken by tree roots. Plumbers installed new schedule 40 pvc from the manhole back to the edge of the driveway, about 30 ft, and included a clean out that was within 100 ft of the other clean out.
