Circulation around a plane wing.
  • Thread starter Thread starter billy92
    Circulation Plane
The discussion focuses on the need to demonstrate mathematically that air flows faster over a wing than below it, using concepts of circulation and vorticity. For low-speed airfoils (M<0.3), a simple inviscid panel method code can be used to calculate circulation by applying the Kutta condition. In contrast, for higher speeds, compressibility becomes significant, and the analysis shifts to shock waves and pressure fields rather than circulation. The Bernoulli principle has been used to show that pressure is lower above the wing, but further clarification is needed on how to prove that speed is greater above the wing. Resources are suggested to aid in understanding these concepts more simply.
billy92
After looking into the lift force i hve been able to calculate most of the things i know. I have however been told that i need to use circulation and vorticity to show that the air flows faster over the wing than below it. I need to show this mathematically by derviving an equation but i am unsure where to start.
Would anybody be able to help without making things too complicated
There isn't some magic equation to use. There is basically no simple way to do it. For a slow (M<0.3) airfoil, the easiest way to determine circulation is probably using a simple inviscid panel method code and enforcing the Kutta condition. That will give you a circulation value.
For faster flows, compressibility becomes important and the problem becomes more difficult. Once you reach the point of having a supersonic leading edge, circulation is no longer the important factor and you can determine lift from the series of shocks and expansions and the resulting pressure fields.
I have been told to use the following resource
http://books.google.co.uk/books?id=...on fluid dynamics&pg=PA18#v=onepage&q&f=false
I was able to show that for a faster speed the pressure is less using bernoulli principle. I now need to show that the speed is greater above the wing. WOuld anyone be able to explain how the link shows this in more simpler terms
Thanks
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
