Selecting the Right MOSFET for Low Voltage and High Frequency Applications
  • Thread starter Thread starter uhdam
    Transistor
Selecting a MOSFET for low voltage (40V) and high frequency (3-4MHz) applications involves understanding the importance of gate drive capability, as all MOSFETs can switch faster than this frequency if properly driven. The primary factors affecting switching speed are input capacitance and drain-gate capacitance, which can slow down the FET. It is crucial to choose a MOSFET with low capacitance and ensure adequate gate drive current to achieve the desired switching speed. Additionally, calculating the Miller equivalent input capacitance is essential for determining the necessary drive capability. Ultimately, selecting the smallest suitable MOSFET that meets power requirements and can be effectively driven will yield optimal performance.
uhdam
Hello,
I need to know that...
how to select the MOSFET for Low Voltage(40v) and High Frequency (3-4MHz) ?
Which MOSFET is suitable for those specifications ?
Please give me the reply...
This is a big topic. 3 to 4 MHz is not very high speed and 40V is very common, there are tons of MOSFET fit your needs. All MOSFET can switch way faster than this provided you can drive the gate. The main factor on speed of the MOSFET is the gate drive. Input capacitance and the drain gate capacitance are the main cause of slowing down the FET. At 3 to 4 MHz, you don't need to worry about the lead inductance and package of the transistor at all.
Some of the big MOSFET can have input capacitance into a few nano farad easily. You need a very high current drive to make it switch at any speed. BUT if you can drive it, you can make it switch fast. I did a lot of pulsing circuits with MOSFET, speed at rise and fall time under 1nS for a 100V transition driving a 10' coax. It takes a MOS driver DS0026 to drive a smaller MOSFET then drive the final big MOSFET!
Back to your question. Depend on your requirement, get the smallest MOSFET possible that can handle the power of your requirement. Then look at the input capacitance and the drain gate capacitance. Calculate the miller equivalent input capacitance. Make sure you can drive the total input capacitance of the combined input and miller cap to get the speed you want. Look into MOS driver IC.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
