Can spin result in an increase of velocity?
A spinning ball can indeed increase its velocity upon hitting the floor, particularly in scenarios involving specific angles and surfaces. The discussion highlights the conversion of angular momentum to linear momentum, suggesting that the interaction can lead to increased speed in the direction of travel. Key equations mentioned include force (f=ma) and torque (T=I alpha), which can be applied to analyze the motion. The phenomenon, likened to a "slam" in ping pong, is influenced by factors such as the ball's material properties and the nature of the impact. Overall, while calculations can be complex due to variable forces and energy conservation, the principles of momentum transfer are central to understanding this effect.
d1v1n1ty nb
If a spinning ball hits the floor is it possible for it to increase in velocity in the direction it is travelling? If so could you please explain with an example? And what Equations would you use? Thanx.
Absolutely - you can do all sorts of crazy things with a rubber ball. If you bounce it from the ground to a wall at a low angle (throw it near the corner), you can even get it to bounce back and forth as its direction of spin and direction of motion both reverse every time it hits the ground.
It may be difficult to caluclate (or rather, difficult to get proper data/assumptions), but you could use angular momentum converted to linear momentum.
Draw a FBD of the ball in contact with the surface, including friction.
Then just apply f=ma and T=I alpha.
It is called a slam in ping pong.
That would be difficult because the force varies and you don't know things like time of contact. It is very dependent on many specific properties of the objects. I was thinking that given a certain elastic modulous, a specific fraction of the angular momentum would be converted to linear momentum.
But you can argue "conservation of energy". If the impact reduces the spin, then the energy due to rotation is reduced and can go into linear kinetic energy.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
