How Much Work Does a Crane Do to Lift Soil?
  • Thread starter Thread starter Iceclover
    Grade 11 Phyics
To calculate the work done by the crane in lifting soil, the mass of the soil must first be determined using its volume and density, resulting in a mass of 2.3 x 10^3 kg. The total weight of the soil can be calculated by multiplying this mass by the acceleration due to gravity (9.81 m/s²), and the weight of the bucket is given as 2.25 x 10^3 N. The total force (weight) to be lifted is the sum of the weight of the soil and the bucket. Finally, the work done can be calculated using the equation W = Fd, where F is the total weight and d is the height of 7.50 m.
Iceclover
A crane lifts a 2.25x10^3 bucket containing 1.15m^3 of soil (density = 2.00x10^3kg/m^3) to a height of 7.50 m. Calculate the work the crane performs.
D=m/V
W=Fd
F=2n25x10^3N
d=7.50m
D=2.00x10^3 kg/m^3
V=1.15m^3
W=?
alright so I've calculated the mass the object will have and i got 2.3 x 10^3kg
Now i was just wondering if anyone could help me on where to go from here?
find the weight of the soil, add it on to the weight of the bucket and use your W=Fd equation.
how do i find the weight of the soil and the weight of the bucket?
weight=mass*g
g=acceleration due to gravity=9.81
you already know the weight of the bucket is 2.25*103 N.
Is it N or kg? You didnt specify and its very important
is what in N or kg? everything is there
