What is the difference between a refrigerator and a heat engine?
The discussion revolves around distinguishing between a refrigerator and a heat engine based on a thermodynamic process involving an ideal monoatomic gas. The gas undergoes an isobaric expansion, an isometric pressure reduction, and an isothermal return to its initial state. Key to this distinction is the sign of the work done; in a heat engine, work is extracted from the system, while in a refrigerator, work is input to transfer heat from a lower to a higher temperature. The participants clarify that in a heat engine, the final temperature is lower than the initial, contrasting with a refrigerator where the final temperature is higher. Ultimately, understanding the relationship between work, heat transfer, and temperature changes is crucial for identifying the device's function.
dav2008
ok..Im doing this review packet for Physics B...I did all of a Thermo problem except one part...
Basically an ideal monoatomic gas first expands in an isobaric process, then the pressure is lowered down isometrically, keeping the volume constant, and finally it is returned to state A isothermally where temperature stays constant...
Part D of the question asks whether this device is a refrigerator or a heat engine... This is what got me confused...I don't even know where to begin...Does it have to do with work being negative or positive?
Part C asked for the net work sign, and i found it was negative(by the new convention at least) because more work was done in the first process (negative, by the gas) than in the third process(positive, on the gas)
..Thanks for any replies..basically i just need to know how to determine if a PV diagram cycle is a refrigirator or a heat engine..tx
OK..i realized it has to do with entropy..but how would i encorporate that with the given information?
something I know
Hi,dav2008...
there are something I know after I look through ur questions...the gas frist expands in an isobaric process,it means that the temperature grows up...because PV=nRT,the pressure fixes,but the volumn gets bigger.Q_in=W_out. W_out=nR ln(V_final/V_inital ).
Then the pressure lowered down,and the volumn keep constant, so the temperature also lowered down.W_out=o, Q_in=nC_v T. T---stands for the amount of changed temperature.and C_v=3/2 R, R=8.31J/(mol*K).
Finally, the temperature stays constant,the final temperature lower than the inital.
So I guess the device is refrigerator. I hope those will be useful for u:wink: ! please reply to me if u know the answer...
Yea lol..its actually a heat engine.i figured it out with teh help of some people...
Since work is negative and done by the gas that means that work is coming out of the system..and in a head engine work is being taken out..Unlike a fridge where work is added
And you are right that the final temperature IS lower than the initial...BUT in a fridge the final temperature is HIGHER than the initial..because u are moving heat from low temperature with the help of work to a higher temperature.
hummm...oic...thanks for ur reply...
I always confuse refrigirator and heat engine...
