Conversion from Parametric to Cartesian
The discussion focuses on converting parametric equations into Cartesian form. For the first set of equations, the conversion was successful, yielding a matching plot. The second set, however, revealed an error in the application of trigonometric identities, leading to a discrepancy in the plotted results. The third set also posed challenges, with suggestions to solve for the parameter t using the quadratic formula for accurate conversion. Ultimately, the discussion emphasizes the importance of careful manipulation of equations and understanding trigonometric relationships in achieving correct Cartesian forms.
W3bbo
Reduce these parametric functions to a single cartesian equation:
<br /> $\displaylines{<br /> x = at^2 \cr <br /> y = 2at \cr} $<br /> <br /> $\displaylines{<br /> x = 3{\mathop{\rm Sec}\nolimits} \left( \alpha \right) \cr <br /> y = 5{\mathop{\rm Tan}\nolimits} \left( \alpha \right) \cr} $<br /> <br /> $\displaylines{<br /> x = t^2 + 1 \cr <br /> y = t^2 + t \cr} $<br />
N/A
For Q1, I think I got the hang of it... in that the plots of my cartesian and the paremetric are identical:
<br /> $\displaylines{<br /> x = at^2 \cr <br /> y = 2at \cr <br /> \cr <br /> t^2 = {x \over a} \cr <br /> t = \sqrt {{x \over a}} \cr <br /> \cr <br /> y = 2a\sqrt {{x \over a}} \cr} $<br /> <br />
For Q2 I thought I had it solved with a trigonometric identity, but the plots look different:
<br /> $\displaylines{<br /> x = 3{\mathop{\rm Sec}\nolimits} \left( \alpha \right) \cr <br /> y = 5{\mathop{\rm Tan}\nolimits} \left( \alpha \right) \cr <br /> \cr <br /> {\mathop{\rm Sec}\nolimits} ^2 \left( \alpha \right) = 1 + {\mathop{\rm Tan}\nolimits} ^2 \left( \alpha \right) \cr <br /> \left( {{\textstyle{1 \over 3}}x} \right)^2 = 1 + \left( {{\textstyle{1 \over 5}}y} \right)^2 \cr <br /> {\textstyle{1 \over 9}}x^2 = 1 + {\textstyle{1 \over {25}}}y^2 \cr <br /> {\textstyle{1 \over {25}}}y^2 = {\textstyle{1 \over 9}}x^2 - 1 \cr <br /> y^2 = {\textstyle{{25} \over 9}}x^2 - 1 \cr <br /> y = \pm \sqrt {{\textstyle{{25} \over 9}}x^2 - 1} \cr} $<br /> <br />
Finally, Q3 seems deceptivly simple, but again, the plot doesn't match the original:
<br /> $\displaylines{<br /> x = t^2 + 1 \cr <br /> y = t^2 + t \cr <br /> \cr <br /> t^2 = x - 1 \cr <br /> y = x - 1 + \sqrt {x - 1} \cr} $<br /> <br />
I'm not looking for answers, just to find out where I've gone wrong.
Thanks
Q2. You've made an error when multiplying through by 25.. you should have a -25 on the RHS of the penultimate line.
Q3. I'm not sure what you've done, but I'd try solving one of the parametric equations for t, but the quadratic formula, then subbing into the other equation.
Thanks. I got those questions correct.
Further on I'm faced with converting this into cartesian:
$\displaylines{<br /> x = 2{\mathop{\rm Cot}\nolimits} \left( t \right) \cr <br /> y = 2{\mathop{\rm Sin}\nolimits} ^2 \left( t \right) \cr} $​
I tried having a go using this:
$\displaylines{<br /> x = 2{\mathop{\rm Cot}\nolimits} \left( t \right) \cr <br /> t = {\mathop{\rm Tan}\nolimits} ^{ - 1} \left( {{\textstyle{2 \over x}}} \right) \cr <br /> y = 2{\mathop{\rm Sin}\nolimits} ^2 \left( {{\mathop{\rm Tan}\nolimits} ^{ - 1} \left( {{\textstyle{2 \over x}}} \right)} \right) \cr} $​
...but the plot is totally different.
I was able to solve it eventually using
$\displaylines{<br /> 1 + {\mathop{\rm Cot}\nolimits} ^2 \left( t \right) = {\mathop{\rm Cosec}\nolimits} ^2 \left( t \right) \cr <br /> 1 + \left( {{\textstyle{1 \over 2}}x} \right)^2 = \left( {{\textstyle{y \over 2}}} \right)^{ - 1} \cr} $p​
But can you explain why my initial attempt failed?
Thanks
Well, when you divide by 2, you should have x/2, not 2/x
Note it's Cot, not Tan. So I inverted the argument for Tan^-1. Otherwise it would have been ArcCot(x/2)
Sorry, I see that now. It's probably some quirk of the graphing software. The first set should work out to the second set if you get rid of the inverse trig functions.
y = 2\sin^2\left[\tan^{-1}\left(\frac{2}{x}\right)\right]
From a picture of the right triangle, we know that
\sin t = \pm\frac{2}{\sqrt{4+x^2}} \implies \sin^2 t = \frac{4}{4 + x^2}
Then,
\frac{y}{2} = \frac{4}{4+x^2}\longrightarrow<br /> \left(\frac{y}{2}\right)^{-1} = \frac{4+x^2}{4} = 1 + \frac{x^2}{4} = 1 + \left(\frac{1}{2}x\right)^2
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
