Displacement in Simple Harmonic Motion
A user seeks help with a physics problem involving a mass-spring system in simple harmonic motion. The mass of 0.27 kg stretches the spring 4.9 cm and is then pulled down an additional 12.5 cm before being released. The user calculates the spring constant (k) and angular velocity (ω) but is unsure how to determine the amplitude (A) for the displacement equation. They clarify that the equilibrium position should be set to zero, and the total displacement from this position is the sum of the initial stretch and the additional pull. Ultimately, the user successfully finds the answer after receiving guidance.
chukie
1. Hi! I am new to this forum. I was wondering if someone could help me with this problem. Thanks in advance!
A 0.27 kg mass is suspended on a spring that stretches a distance of 4.9 cm. The mass is then pulled down an additional distance of 12.5 cm and released. What's the displacement from the equilibrium position with the mass attached (in cm) after 0.42 s? Take up to be positive and use g = 9.81 m/s2.
F=kx
ω(angular velocity)= (k/x)^0.5
First I solved for k:
k=mg/x
k=(0.27*9.81)/4.9
k=0.54
Then I solved for the angular velocity:
ω=(0.54/0.27)^0.5
ω=squareroot 2
Then I tried to come up with an equation for displacement using the format:
x(t) = Asin(ωt)
i know that ω=root2
t=0.42
but how do i solve for A?? or what is A? should it be 4.9 or 12.5 or the sum of the two :confused: btw please correct me if I am wrong in my calculation. thanks!
4.9 cm is the location of the equilibrium position. They're asking you to find the displacement after t seconds relative to the equilibrium position, so set your equilibrium position to 0. From the equilibrium position, they extended the displacement by 12.5 cm.
You know anything about S.H.M equations?
thanks! i got the answer now =)
