Planet is 2.00 a.u. when closest to sun. eccentricty is .500. find period
To find the orbital period of a planet with a perihelion distance of 2.00 astronomical units (a.u.) and an eccentricity of 0.500, the semi-major axis (A) is calculated to be 4.00 a.u. Using Kepler's third law, the relationship T^2 = a^3 is applied, leading to T = 8 years. The calculations confirm that the period is indeed expressed in years. The discussion highlights the importance of correctly applying Kepler's laws to determine orbital characteristics.
c-murda
a planet is 2.00 a.u. when it is closest to the sun. its eccentricity is .5000. Find its period in years.
i got this so far... don't know if it is right
PD + AD = A
-AD - PD = F <SUBTRACTING THESE TWO>
2PD = A - F
2PD = A - (EA)
2PD = A(1-E)
2PD/(1-E) = A
A = 2(2)/(1.-.5)
A= 8 a.u.
then for a
a= 8.00/2
a= 4.00 a.u.
T^2 = a^3
T = sqrt(a^3)
T = 8
im lost T = 8 what? years?
kepler's 3rd law says Period( in years) is directly proportional to semi axis (a) cubed. correct?
so was that last line:
T^2 = a^3
correct?
anyone i got a 7 15 dead line
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
