Energy of a Capacitor in the Presence of a Dielectric
The discussion focuses on calculating the energy of a dielectric-filled parallel-plate capacitor under various conditions. The initial energy of the capacitor, while connected to a battery, is correctly identified as (epsilon_0*K*A*V^2)/(2d). When the dielectric is half removed, the capacitor can be modeled as two capacitors in parallel, one with dielectric and one without, to find the new energy. The user struggles with the calculations for the energy when the dielectric is partially removed and when the capacitor is disconnected from the battery. The key to solving these problems involves correctly applying the principles of capacitance and energy storage in capacitors.
odd_concept
An dielectric-filled parallel-plate capacitor has plate area A and plate separation d. The capacitor is connected to a battery that creates a constant voltage V. The dielectric constant is K.
A. Find the energy U_1 of the dielectric-filled capacitor. The capacitor remains connected to the battery
I was able to figure out this one:
But I cannot figure out the rest...
B.The dielectric plate is now slowly pulled out of the capacitor, which remains connected to the battery. Find the energy U_2 of the capacitor at the moment when the capacitor is half filled with the dielectric. Express your answer in terms of A,d,V,K,epsilon_0.
C.The capactor is now disconnected from the battery, and the dielectric plate is then slowly removed the rest of the way out of the capacitor. Find the new energy of the capacitor, U_s.Express your answer in terms of A,d,V,K,epsilon_0
D. In the process of removing the remaining portion of the dielectric from the disconnected capacitor, how much work W is done by the external agent acting on the dielectric.Express your answer in terms of A,d,V,K,epsilon_0
ANY help would be greatly appreciated... Thanks in advance
When the capacitor is half filled with the dielectric, you can imagine two capacitors having area A/2 each and connected in parallel. One of them is with dielectric and other without dielectric. Calculate the equivalent capacitance and charge on it. By this hint you can solve C and D
I tried this for C and it was wrong?
epsilon_0*K*(A/2)*V^2/(2d)
what am I doing wrong?
C1 = epsilon_0*A/2*/d and C2 = epsilon_0*K*(A/2)/d. Since the battery is still connected the potential difference is same in C1 and C2.
