Un-damped Driven Harmonic Oscillator Question
Niner49er52
An un-damped driven harmonic oscillator satisfies the equation of motion: ma+kx=F(t) where we may write the un-damped angular frequency w-naught^2=k/m. The driving force F(t)=F-naught*sin(wt) is switched on at t=0. Find x(t) for t>0 for initial conditions x=0, v=0,at t=0.
I know that this can be written in terms of a complimentary and a particular solution and that the complimentary solution will be in the form x(t)=Asin(w-naught*t-delta) and that I need to consider a particular solution in the form x(t)=Asin(wt) and determine A by plugging x(t) into the differential equation.
The final answer is given as x(t)= -((F-naught/m)(w/w-naught)/(w-naught^2-w^2)) sin(w-naught*t) + ((F-naught/m)/(w-naught^2-w^2)) sin(wt)
Ive done similar problems that have worked out but for some reason I can't get this to come out right. It's driving me nuts I've been working on it all weekend and have to turn this work in tomorrow morning.
What do you get for A when you plug your particular solution into the DE...what does that give you for your general solution?
ok, i got that part. A will equal (F-naught/m)/(w-naught^2-w^2). I think I was just writing it wrong when I plugged into the DE. Now I just have to work through the complimentary part.
hmm, I know this should be the easy part but I'm stuck again! I can't seem to figure out how to solve for A in the complimentary part.
You'll have to use the initial condition that you were given: x(0)=x'(0)=0...remember that these condition apply to the total solution, not just the complimentary part.
thanks, that's what's probably getting me here. appreciate all the help
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
