What is the equation for approximating propeller thrust at a known RPM?
  • Thread starter Thread starter thomasxc
    Propeller Thrust
To approximate propeller thrust at a known RPM, it's essential to consider propeller efficiency, engine horsepower, and velocity. Static thrust differs from dynamic thrust, and this distinction is crucial for accurate calculations. Reference materials, such as Raymer's "Aircraft Design," provide detailed equations and insights on this topic. Proprietary information from manufacturers may be necessary for precise data, especially for certified aircraft. Understanding these factors is vital for effective propeller design and performance assessment.
thomasxc
Is there some equation i can use in order to approx. find the trust created by a prop at a known RPM??
-Tom
prop websites normally have this graphed, though as you may know, static thrust is different than dynamic thrust.
I designed an airplane and competed with it once.
Attached is my teams report. You may find some interesting information in this document.
Pg 24 talks about thrusts and stuff.
enjoy...
-Tom
You can look up the propeller efficiency. You need to know this number, along with the velocity and HP of the engine to calculate the net thrust.
Page 396 in Raymers book, "Aircraft design" by the AIAA explains this.
enjoy...
Actually, that's proprietary information they don't give on their websites. I've had to call up the engineers at McCauley to get this information.
I think you are talking about model airplane propellers, whereas I am talking about propellers for FAA certified aircraft 2000lbs+.
Nice CAD drawing. All in all, looks like a very fun senior design project (if that's what it is).
yes, i was talking about models :).
and yes it was a senior design project. was a lot of fun lol
Agree, energy method is very useful at initial sizing and that suits you case.
But make sure you get the loading rate that's a good problem.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
