Engineering Output of the circuit as function of time
The discussion revolves around plotting the output of a circuit with an ideal diode model given an input voltage of Vin = V0 cosωt. Participants clarify that when Vin is more negative than -2V, the diode conducts, acting as a short circuit, while otherwise, it acts as an open circuit. It is concluded that the state of the diode does not affect the output voltage (Vout) in this specific circuit configuration. The original poster eventually figures out the solution, expressing gratitude for the assistance received. The thread is marked for closure by moderators after the resolution.
atan691988
can anyone help me with this>>>
* If the input is Given by Vin = V0 cosωt, plot the output of the circuit as function of time. assume an ideal diode model. *
Often, in introductory courses, "ideal diode" means zero forward voltage and zero reverse current.
Write V_out in terms of the DC voltage source 2V and v_in.
When V-in* is more negative than -2, diode is on so replace it with short circuit. Else diode is off, replace it with open circuit.
But, does it really matter whether diode is on/off in this circuit?
Now that I can see the circuit ... no, you're right it does not affect Vout here.
Gahh! I didn't look at the graphic because I thought it was one of those "pending admin approval" things. Its a link! This is easy.
Hint 1: An ideal voltage source is unaffected by the current that is being drawn from it.
Hint 2: Consider V_in and the battery as your "ideal voltage source"
(Sheesh I practically gave you the answer)
It was a "pending admin approval" thing. Eventually an admin approved it.
That was question to the OP because I didn't want to provide him a direct answer :smile:
hahaha. thanks for all your replies guys.
I've already figure it out..
but really thanks to all :D
<<< mods can close these thread.
