General loading, shear and moment relationships
The discussion revolves around understanding the internal moments and shear forces in a loaded beam. A participant expresses confusion about the direction of forces, questioning why one force is upward and another downward, suggesting they should cancel out. Responses clarify that the forces are consistent with Newton's third law, and that the direction of arrows in force diagrams can be arbitrary; if guessed incorrectly, the resulting values will simply be negative. The conversation also touches on calculating bending stresses in a C-section beam, with one participant struggling to interpret the signs of the stresses at different points. The thread concludes with a suggestion to start a new discussion for further assistance on the bending stress calculations.
emRage
Hi everyone,
I'm struggling to get my head around the convention of internal moments and shear forces of a loaded beam.
I just can't seem to make any sense of why F is facing upwards and F+dF is facing downwards. It's driving me absolutely insane. Surely both of them will be facing upwards to cancel out wdx?
Please help =/
Thank you.
Hi emRage! :smile:
No, the F upward shown on the left of the section matches the F downward (not shown) on the right of the next section to the left (Newton's third law!).
And the next section to the right will similarly have an F + dF upward on its left (not shown), and that matches the F + dF downward shown.
To look at it another way …
the wdx is a very small amount, and tends to zero as dx tends to zero.
It must therefore be "cancelled" by an equally very small amount …
and that isn't going to be the rather large F + F + dF, is it? :wink:
Thank you tiny-tim,
Now my next question is:
The arrows for F and F+dF are facing that way to cancel out the hidden F and F+dF. Why do the (visible) arrows have to face that particular direction? Because if I were to change the direction they are facing, that would change the shear force and bending moment equilibrium eqtns am I correct?
They don't have to.
If you put the arrows that way round, and then solve the equations, you'll find that F will come out negative.
In some problems, it isn't at all obvious which way up they should be, so you just have to make a guess, and if the guess turns out wrong it doesn't matter … you'll have, say, -3N up instead of 3N down … same thing. :smile:
Thanks for ur help, Ok so here's the next question,
C-section beam of 300mm , Sy = 1000N
Finding bending stresses 100mm from the point of load...The force causes compression on top and tension on the bottom hence bottom stresses should be +ve and top stresses -ve.
100mm from the point of load would mean a bending moment of 1000x100 = 100000Nmm in the positive sense about x-axis.
The bending moment caused by Sy in this case is +ve Mx (moment in the x-axis). Am I correct?
I'm getting positive values at the top corners and negative at the bottom corners for bending stress which is clearly wrong!
Regards.
emRage said:
Thanks for ur help, Ok so here's the next question,.
uh-uh, can you please start a new thread?
(and can you make it clear where the point of application of the force is?)
Then other members will come in and help …
all this stress and moment is getting a bit out of my depth. :redface:
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
