What is the electric flux through the rectangle
The discussion focuses on calculating electric flux through a rectangle and a box in different electric fields. For the rectangle in the xz-plane, the electric field E=(50i+100k) N/C has no j component, indicating that the flux through the rectangle is zero since the field is parallel to the surface. In the second problem, the electric field E=(50i+100j) N/C has a j component of 100 N/C, which contributes to the flux through the box. The area of the box is 1 cm², and with the electric field strength of 1000 N/C, the calculated flux is 0.001. The discussion emphasizes understanding the components of electric fields in relation to the surfaces they interact with.
spatel600
Question 1: A 2cm x 3cm rectangle lies in the xz-plane. What is the electric flux through the rectangle if
E=(50i+100k) N/C
and
E=(50i+100j) N/C
Question 2:
A 1cm x 1cm x 1cm box is between the plates of a parallel-plate capacitor with two faces of the box perpendicular to E . The electric field strength is 1000 N/C.
What is the electric flux?
So far i have gotten .001
Any suggestions?
PLEASE HELP!
When it comes to the i,j,k stuff I always can never figure it out. Please help!
hello, could u help me with my physics homework?
elizabethg: Please don't "hijack" someone else's thread. All homework questions should be posted in the appropriate homework forum- ask specific questions and show what you have done on the problem yourself.
SpateI600: The rectangle is in the x-z plane so only that part of the field in the y (or j) direction give flux through it.
In problem 1, E=(50i+100k) N/C which has NO j component- it is parallel to the rectangle and doesn't cross it. What does that tell you about the flux through the rectangle?
In problem2, E=(50i+100j) N/C. The j component is 100j N/C. Now think about what N and C mean and the area of the rectangle.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
