Force problem What is the electric force on q3 due to the other 2 charges?
The discussion revolves around calculating the electric force on a charge q3 (1.0 µC) due to two other charges, q1 (0.71 µC) and q2 (-0.67 µC), arranged in a right triangle. Participants emphasize the importance of converting forces from polar to rectangular coordinates to avoid mistakes and correctly determine the x and y components of the forces. The repulsive nature of the forces between q1 and q3, both being positive, is noted, affecting the signs of the components. The calculations involve using Coulomb's law (kq/r^2) and ensuring proper conversion of units from microcoulombs to coulombs and centimeters to meters. The thread highlights the need for clarity in understanding vector components and their directions in force calculations.
Ammora
Three point charges are fixed in place in the right triangle shown below, in which q1 = 0.71 µC and q2 = -0.67 µC. What is the electric force on the +1.0-µC (let's call this q3) charge due to the other two charges?
image: http://www.webassign.net/grr/p16-15alt.gif
magnitude ____ N
direction ______°, measured counterclockwise from the +x-axis
kq/r^2
The only thing I don't know how to do is calculate the x and y components of the charge on q3 due to q1.
Here's what I did:
First I found the missing side, 6 cm. Then I converted all the cm to m by multiplying it by .1 m and then I converted all the uC to C by multiplying it by X10^-6.
q1: Fx= k(q1)(q3)/r^2
= 8.99e9 (0.71e-6) (1.0e-6)/(0.10)^2 * 6/10
Fy=k(q1)(q3)/r^2
= 8.99e9 (0.71e-6) (1.0e-6)/(0.10)^2 * 8/10
q2: Fx=k(q2)(q3)/r^2
=8.99e9 (-0.67e-6) (1.0e-6)/(0.10)^2
Total force= Fx added together. And then sqrt. (Fx^2 + Fy^2)
As for the direction, tan theta= (Fy/Fx) and then add 180 to it?
Please help me, it's due tonight, thank you so much in advance.
magnitude ____ N
kq/r^2
Here's what I did:
Fy=k(q1)(q3)/r^2
Welcome to the PF.
You should convert the polar form of the vectors to rectangular form, add the forces in rectangular form, and then convert back to polar form. Otherwise, it's too easy to make mistakes.
The polar --> rectangular conversion for the force due to q2 is easy, since all of the force is in the x direction, right? What about the conversion for the force due to q2? Can you show us the x and y components of that force? And then add the forces component-wise, and convert back to the polar answer format that they are asking for...
Welcome to the PF.
Thank you so much, this forum is awesome, you replied so quick!
I don't know what polar or rectangular form mean, I'm sorry, I'm in Intro physics.
I think the x-component of the force q2 is (0.71e-6 cos 30) and the y-component is (0.71e-6 sin 30)?
Can you please let me know if I'm on the right track?
Good, except watch your signs. q1 and q3 are both +, so the force is repulsive or attractive? And given the answer to that, you need to call the component of the force in the + direction positive if it points in the direction of the + x axis, and negative it if points in the direction of the - x axis. And the same thing for the y component of the force.
Once you have the x and y components of the forces (making sure the signs are right), add the x components to get the resultant x force, and add the y components. Then covert back to the polar form that the question asks for.
Since they're both +, the force is repulsive.
So I have:
q2: Fx= - k(0.71e-6)(1e-6)/(0.71e-6 cos30)^2
Fy= - k(0.71e-6)(1e-6)/(0.71e-6 sin30)^2
(both components are negative, because the force points in the negative x direction, since they're repulsive to the positive charge of q3.)
q3: Fx= k(-0.67e-6)(1e-6)/(0.6)^2
So, Fx= 532160742267 + -0.0167313889 = 5.32160742e11
Fy= -1.29705876e10
What does "polar form" mean?
So I have:
Fy= -1.29705876e10
Sorry, Q2 is in line with Q3 on the x-axis, so I don't understand how you have x and y components to that force. I could be spacing something, though.
Polar/Rectangular component conversions:
http://en.wikipedia.org/wiki/Polar_coordinate_system
