How Do You Calculate the Maximum Height of an Object Thrown Vertically Upward?
  • Thread starter Thread starter kimikims
To calculate the maximum height of an object thrown vertically upward with a speed of 58 m/s at two-thirds of its maximum height, the equation V^2 = Vo^2 + 2g(2/3H) is used, where V is the final velocity, Vo is the initial velocity, and g is the acceleration due to gravity (9.8 m/s²). The initial speed is considered zero when analyzing the object's motion from the peak height down to the point where it reaches 58 m/s. To isolate H, one can rearrange the equation by dividing or multiplying both sides appropriately. The discussion emphasizes understanding the motion dynamics and correctly applying the kinematic equations. Ultimately, the maximum height can be determined by solving the rearranged equation.
kimikims
An object is thrown vertically upward such that it has a speed of 58 m/s when it reaches two thirds of it's maximum height above the launch point.
The acceleration of gravity is 9.8 m/s^2
Find the maximum height h. Answer in units of m.
I know:
V: 58 m/s at y=2/3 H
H = ?
V = 0
V^2-Vo^2 = 2g(1/3H)
I know I need to plug in the numbers, but how do I get all of the equation to one side, to find H??
kimikims said:
V^2-Vo^2 = 2g(1/3H)
Right (where Vo = 0).
Divide or multiply both sides to eliminate what's in front of H.
For example, if you had an equation: 7x^2 = 67bZ, and you wanted to isolate Z, just divide both sides by 67b: (7x^2)/67b = (67bZ)/67b = Z; so Z = (7x^2)/67b. Make sense?
You got
V^2 = V_{o}^2 + 2g\frac{2}{3}H
where V is 58 m/s
and
0 = V_{o}^2 + 2gH
Doc Al, how come initial speed = 0 ?
If you look at the motion on the way down, then the object starts from rest and falls a distance of H/3 to reach a speed of 58 m/s.
Oh Yes, i wasn't thinking about it :biggrin:
