Direction of Induced Current in a Small Loop Inside a Solenoid
A small circular loop inside a hollow solenoid experiences induced emf due to a decreasing current in the solenoid. The right-hand rule indicates that the induced current in the loop should be clockwise, opposing the decrease in the solenoid's counterclockwise current. This leads to confusion regarding the magnetic field direction produced by the solenoid's current. The discussion highlights the need to reconcile the behavior of induced current with the steady current's magnetic field, suggesting a deeper understanding of Maxwell's equations and electron drift. Clarifying these concepts is essential for grasping the relationship between electric current and magnetic fields.
SaraF
This is a question from the Princeton Review of AP physics B, 2011 edition. A small circular loop of wire (radius r) is placed on an insulating stand inside a hollow solenoid of radius R. The solenoid has n turns per unit length and carries a counterclockwise current I. (The magnetic field within the solenoid is shown as pointing into the plane of the page.) If the current in the solenoid is decreased at a steady rate of a amps per second, determine the induced emf and the direction of the induced current in the loop.
B = uonI. E = -d(BA)/dt
I determined the equation for the EMF induced in the small loop correctly. I had a problem with the direction of the current. By the right hand rule, the current should be clockwise, and that is the text's correct answer. However, by the same right hand rule, I would expect the counterclockwise current in the solenoid to produce a magnetic field pointing out of the plane of the page, not into it.
Initially, I thought that the current in the small loop would be counterclockwise, because that is the direction specified for the current in the solenoid. Since the solenoid current is decreasing, the current induced in the ring would oppose that decrease, and therefore be in the same direction as the current in the solenoid, ccw. Now I am confused as to how a ccw current in the solenoid could even produce a magnetic field pointing into the plane of the page, as that conflicts with the right hand rule. I'm hoping that someone can clear up this confusion for me.
the answer will be Counter-clockwise, if the current is decreasing.
Thanks, I wondered if that was the case. But that implies that a decreasing clockwise current is the same as a counterclockwise current. That is hard to reconcile with the image of electrons moving through a wire...one pictures a decreased "flow" rate but no change in direction. I realize that the flow of electric current in a wire is not really the flow of electrons from point A to point B (given the collisions between electrons and atomic nuclei, etc)...so that makes we want to understand better what is happening when electric current flows through wires. I wonder about the relation between induced current (requires change of magnetic field) and the magnetic field created by a "steady" current in a wire. Is there, actually, something changing in the current that "induces" a magnetic field? (i.e. is there some sort of reciprocity between electric current and magnetic field that works both ways?)
you would need to study maxwell's equations to understand it. also study about electron drift.
Thanks. I will do so. I figured that electron drift had something to do with it.
