Electric field of a charged ring.
The discussion focuses on calculating the electric field at point P due to a uniformly charged ring. The charge of the ring is Q=6.10 microCoulombs and its radius is R=1.30 cm, with point P located at z=4.00 cm. The electric field is derived using the formula E=kQ/(r^2) and integrating over the charge elements of the ring, considering symmetry and the vertical direction of the electric field. The final expression for the electric field at point P is E_z = (kQx)/((x^2+R^2)^(3/2)), which simplifies the calculation by integrating from 0 to 2π. The solution emphasizes that alternative methods may exist for deriving the same result.
NeverSummer
bionut said:
As part of the optics in a prototype scanning electron microscope, you have a uniform circular ring of charge Q=6.10 microCoulombs and radius R=1.30 cm located in the x-y plane, centered on the origin as shown in the figure.
What is the magnitude of the electric field, E at point P located at z=4.00 cm ?
E=kQ/(r^2)
dE=kdQ/(r^2)=kdQ/(sqrt(h^2+r^2))=∫(k/4.206)dQ
=2.14*10^9 Q
Now, I'm not sure I've made it thus far correctly, so if I've gone wrong, please let me know. Either way, I have no idea what my limits of integration would be for this, so I'm pretty much stuck here.
I kind of follow your work, but I'm afraid I don't see the complete equation needed, so I will go ahead and derive it for you.
Alrighty, here's a little picture to help us out.
Let's keep this in mind throughout the whole problem.
We know by symmetry that the electric field due to the ring at point P is going to be straight up in the Z direction. In the picture, I have the electric field element \begin{equation} dE \end{equation} due to a charge element \begin{equation} dq \end{equation}.
Let us define that charge element. Because we have a ring, it will have a linear charge density (charge per unit length), \lambda = Q/l = Q/2\pi R, where L (lower case in the equation) is the circumference of the ring, it's length. Let's look at another picture for substitution reasons:
This picture shows us that \begin{equation} dl=Rd\theta \end{equation}.
So now we can say (using the equations above) \begin{equation} dq=\lambda dl = \frac{Q}{2\pi R} Rd\theta = \frac{Q}{2\pi} d\theta \end{equation}
Let's not forget any of this as we move on!We know from the equation of an electric field that \begin{equation} dE = k \frac{dq}{r^2} \end{equation}. Where \begin{equation} r=\sqrt{R^2+x^2}\end{equation} - from the first picture.
Like said before, we know that the electric field is going to be vertically up in the Z direction, so we want to find the electric field straight up (dE_z) due to our charge element, we can use trig from our first picture to say this: dE_z = dE \cos{\theta}
And we know from our first picture again that \cos{\theta} = R/r
Now let's do some substitution using A LOT of what we have done before:
dE_z = dE\cos{\theta}
dE_z = k \frac{dq}{r^2} \frac{x}{r}
dE_z = k \frac{Q/(2\pi)}{x^2+R^2} \frac{x}{\sqrt{x^2+R^2}} d\theta
\int dE_z = \frac{k}{2\pi} \frac{Qx}{(x^2+R^2)^{3/2}} \int_{0}^{2\pi} d\theta <-- integrating from 0 to 2pi (the whole ring) = 2*pi
And now we have our solution:
E_z = \frac{kQx}{(x^2+R^2)^{3/2}}
Now all you do is plug your numbers in
By the way this is not the only way to reach this solution, just the way I was taught. If you google "electric field due to a ring of charge" - you may find some other ways
Thanks for the great explanation, I got it!
