Counter rotation theory problem
The discussion revolves around the motion of a meter stick placed on two counter-rotating wheels, with one wheel rotating clockwise and the other counter-clockwise. The initial confusion stems from whether the stick will remain stationary, oscillate, or be displaced due to its off-center position. Experimentation suggests that when the stick is centered, it remains stationary, but when off-center, it tends to fall. The key takeaway is that the friction and the initial off-center placement influence the stick's motion, leading to the conclusion that it will likely be displaced to the right. Overall, the problem highlights the complexities of balancing forces and the effects of friction in rotational systems.
Smartguy94
A meter stick rests on two counter-rotating wheels. The left wheel rotates clockwise while the right wheel rotates counter-clockwise. There is friction between the meterstick and each wheel. The meter stick begins off-center to the right. What is the resulting motion of the meter stick?
Wouldn't the meter stick simply just not move because the two wheel velocity cancel one another? but I got it wrong.
would it be The stick will be sent off the wheels to the right?
because the stick was off-center to the right at first?
or would it be The stick will oscillate back and forth?
or Nothing can be said about the stick's motion?
or The stick will be sent off the wheels to the left?
I'm quite confused
If the wheels rotated slowly the stick would be balanced between the wheels. Make the following to prove it to yourself,
i tried to do the experiment, but it simply won't work because when i put the ruler off-centered to the right the ruler keep falling. however, i tried to do it when the ruler is centered, and the result is that the ruler doesn't move anywhere if i rotate both of the wheels with same speed. which means that the ruler stays on the same spot, but again it's not the answer.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
