Seeming simple Thermodynamics problem
  • Thread starter Thread starter StickNinja
    Thermodynamics
The discussion addresses a thermodynamics problem involving a balloon inflated with 5 liters of monatomic gas, initially at 0 degrees Celsius and heated to 60 degrees Celsius at 1 atm pressure. It calculates the heat absorbed by the gas when the balloon does not expand, resulting in a change in internal energy (ΔU) of approximately 166 J. When the balloon expands freely at constant pressure, the change in internal energy is calculated as 277.47 J, leading to work done by the gas of about 111 J. The calculations consider the ideal gas law and the specific heat capacities for monatomic gases. The importance of accounting for mass flow and boundary work in the analysis is also noted.
StickNinja
A balloon is inflated with 5 liters of monatomic gas at 0 degrees Celsius and heated to 60 degrees Celsius at 1 atm. pressure.
R=8.31J/mol K, Cp=5R/2, and Cv = 3R/2
1. If the balloon does not expand, the heat absorbed by the gas would be what?
2. If the balloon expands freely at constant pressure, the work done by the gas would be what?
...Took me a while, but I figured it out (no mass is entering the system). So here is the solution in case others want to know.
For #1 PV=nRT
P=1 atm=1.01*10^5 Pascals
V=5 liters=.005 m^3
n=Unknown
R=8.31 J/mol K
T=273K, Given
Solving for n, we get .222601 mols
ΔU=nCvΔT --constant volume
ΔU=n*3R/2*60= 166J roughlyFor #2
ΔU=nCpΔT
ΔU=277.47
ΔU=Q+W
W=111J
You'll have to take into account the mass flowing into the system. There may also be boundary work involved.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
