Finding resistor's voltage with current and voltage sources present
To find the voltage across resistor R2 in a circuit with both current and voltage sources, first convert the 4 V source and R2 into a current source, resulting in I_2 of 40 mA. Combining this with the existing current source I_1 gives a total current of 50 mA. Using the current divider rule, the current through R2 is calculated to be 10 mA, leading to an initial voltage across R2 of 1 V. However, simulations indicate a voltage of 3 V across R2, which is confirmed by analyzing the original circuit and applying Kirchhoff's Voltage Law, revealing that the voltage across R2 is indeed 3 V after accounting for the voltage drop across R1.
JJBladester
What is the voltage across R2? You should convert the 4 V source and resistor into a current source as your first step.
The first thing I did is create a second current source out of the 4 V voltage source and the series resistor R2. I called it I_2.
I_2 = E/R_2 = 4V/100Ω = 40 mA
This gives us:
We can combine the parallel current sources I_1 and I_2:
I = I_1 + I_2 = 10 mA + 40 mA = 50 mA
By the current divider rule,
I_R2 = (R_T*I)/R2 = (20Ω*50mA)/100Ω = 10 mA
V_R2 = I_R2*R2 = 10mA * 100Ω = 1 V
However, when I run a simulation of the original circuit using MultiSim, I get 3 V through R2. Where am I going wrong?
This gives us:
If you get 3 V across R2 in the original circuit, that means that there voltage dropped across R1 in the original circuit is 1 V, which makes sense.
The difficulty appears to be that you are assuming the resistor, R2 in the original circuit has the same voltage across it as the resistor, R2, in the last two circuits.
I'm stuck. I think I understand what you mean that R2 in the new (simplified) circuit cannot be treated the same as R2 in the original circuit. Am I correct up to the point where I found a combined 50 mA current source acting on two parallel resistors R1 and R2?
If so, how do I get back to finding the voltage for R2 in the original circuit.
Find the voltage across R1 in the simplified circuit. It hasn't been changed. Then use that to find the voltage across R2 in the original circuit.
I = I_1 + I_2 = 10 mA + 40 mA = 50 mA ✔[/size][/color]
[strike]There are two mistakes in this line, yet you end up with 10 mA and that's the right answer[/strike]https://www.physicsforums.com/images/icons/icon4.gif
Oops, my mistake. What you are using is not what I think of as current divider rule, but it's okay.
So I can't use the "new" R2 even though it is the same R2 as before?
Anyway, using your advice to find the voltage across R1 in the simplified circuit, I've found the voltage across R2 using Kirchhoff's Voltage Law on the original circuit:
Using the current divider rule:
I_{R1}=\frac{(20\Omega )(.05 A)}{(25 \Omega )}=.04A
V_{R1}=\left (I_{R1} \right )\left (R_1 \right )=\left ( .04A \right )\left (25\Omega \right )=1V
E - VR2 - VR1 = 0
VR2 = E - VR1 = 4V - 1V = 3V
