Heat Transfer Refrigeration Problem
To estimate the cooling time for a trailer filled with coke from 22°C to 4°C, key factors include the refrigeration unit's heat transfer capability of 10 kW, the specific heat capacity of coke, and the trailer's dimensions. The cooling process involves multiple heat transfer mechanisms: radiation, convection, and conduction through the trailer's walls and insulation. The total mass of coke and its density must be determined based on the container sizes and loading method. Calculating the effective thermal resistance will help assess the insulation's impact on cooling efficiency. Ultimately, the time required to reach the desired temperature can be derived from the mass of coke, its heat capacity, and the heat transfer rate.
mellowoout
Estimate how long a time it will take to cool a trailer filled with coke ?
Given the ambient temperature is 22 degrees C and heat transfer provided by the refrigeration unit is 10 kW and the drinkable temperature is 4 degrees C. Make reasonable estimates of how much insulation is included on the walls of the truck. Assume an air flow velocity inside the truck of 0.1 m/s. Assume the sun is incident on the external surface of the truck for part of the time. Indicate any assumptions you make in your analysis. Take the properties of coke as: specific heat capacity 4200 J/kgK, density 1000 kg/m^3 and thermal conductivity of 0.6 W/mK.
6.1m X 1.6m X 1.5m or 20ft X 6ft X 5ft
The actual heat transfer given out by your refrigeration unit will be different than your input power (10KW) if that's the case?. Even with insulation your going to get some loss. I think the actual time to cool it down to steady state temperature won't be long given your power and convection.
mellowoout. Good day ( why the extra o )
I guess your first guestimate is how full is the trailer of coke - a range of a minimum of one bottle or packed full to the brim - which you would estiamte by the type of the coke container ( bottles or cans ), size of container ( 950 ml, 1 L, 2 L ) , cans/bottles per case, and the number of cases per pallet, and the number of pallets per trailer ( single or double or triple stacked ). That is if you use pallets or just load the cases directly into the truck. I guess you will have to go the store and see what size case(s) coke comes in.
So you have to decide how much coke is in the trailer is and that would be your first assumption.
Ok so starting outside and working in, you have:
(A) Heat of radiation, depending on the reflective/absorptive characteristics of the outer panels.
(B) Heat of convection outside, based on the 22C and, say, 100kph wind speed (highway), assume its fairly turbulent, over a smooth flat plate... I'm not going to look up the Reynolds numbers and Nusselt numbers but yeah.
(C) Heat of conduction through the outer panel (steel?).
(D) Heat of conduction through the insulation (this is the unknown in the equation)
(E) Heat of convection between inside wall and inside air, based on 4C and that .1m/s air speed pulling heat from the wall into the room air.
(F) Heat of convection between inside air and coke can, again using 4C and .1m/s.
(G) Heat of conduction through coke can wall.
(H) Heat of conduction through coke liquid (neglect convection here if the coke is sittin still.
(I) Heat of convection between inside air and cooling coil wall. (given as 10kW of thermal energy)
Items (A) through (H) can either be calculated the hard way, or looked up in an ASHRAE table somewhere. There's some equivalent thermal resistance. Invert that, multiply by the surface area of the truck walls and the temperature difference (18C). You'll get something like (U_insulation*Area_of_walls + U_otherstuff*Area_of_otherstuff )*dT = 10kW, where U_otherstuff is found by math wizardry, and U_insulation is unknown. We're assuming that 10kW is enough to get us down to 4C on the inside, and solving to figure out what value of U_insulation makes that true. Then simply invert U_insulation to figure out the R-value of the insulation. As for the amount of time, t = mass_of_coke * heat_capacity * delta_T / 10kW. As far as time goes, it doesn't really matter *how* that heat is transferred since you already know how *much* is transferred... (mass of coke is total volume of coke (you pick!) times density.(side-note: upon further review, the above is anything but simple... it made far more sense to me when typing it than I'm sure it will to anyone reading it. sorry!)
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
