Mechanics question on vector statics
To determine the reactions at points B and D with b = 60mm, the discussion highlights the challenge of having four unknowns (Bx, By, Dx, Dy) but only three independent equations from static equilibrium. The user initially struggles to find a fourth equation, having established equations for horizontal and vertical forces and moments about point B. A suggestion is made to consider the forces at point C and to label the components of the system for clarity. Ultimately, the user confirms they found the solution after further analysis.
ashishsinghal
Determine the reactions at B and D when b = 60mm ?
(Diagram is attached)
Since B and D are hinged we don't know the direction as well as magnitude of the reaction forces at B and D. Hence we have 4 unknowns (Bx, By, Dx, Dy).
But I can't find 4 independent equations. I got three by ƩFx= 0, ƩFy= 0 and moment about B = 0. Where is the 4th equation. Please help.
hi ashishsinghal! :smile:
it's static, so what can you say about the forces at C ? :wink:
Call the ABC piece number 1 and the CD piece number 2. You know the force at point A so you have six unknowns, the two components of force at points B, C and D. You have six equations:\sum F_{1x}=0\sum F_{1y}=0\sum F_{2x}=0\sum F_{2y}=0\sum \tau_1=0\sum \tau_2=0 where \tau is torque. (I assume "b" is not an unknown).
Thanks Rap I got the answer.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
