Average Acceleration Question for Bullet Through Board
The discussion revolves around calculating the average acceleration of a bullet passing through a board. The bullet enters at 200 m/s and exits at 100 m/s, with a thickness of 5.0 cm. The user calculated the time taken to pass through the board as 0.000333 seconds, leading to an average acceleration of -300300 m/s². The solution confirms that using kinematic equations is appropriate for this scenario, as it assumes constant acceleration. The approach taken aligns with established physics principles, validating the calculations.
DrDonaldDuck
"A bullet is fired through a 5.0 cm thick board of some material. The bullet strikes the board with a speed of 200 m/s, and emerges out the other end at 100 m/s.
a= (change in velocity)/(change in time)
average velocity = .5(initial v + final v)
a= (-100 m/s)/(.000333 seconds) = -300300 m/s^2
I found .000333s as the time it took for the bullet to pass through the board, using the average velocity of 150 m/s.Is this correct?
SOLVED.
It helps, if you are unsure of your reasoning, to relate what you did with some other representation... eg. from your equations:
ave speed = distance over change in time:\frac{d}{T} = \frac{1}{2}(v + u) \Rightarrow 2d = (v + u)T... using distace d, change in time T, final velocity v, initial velocity u.
acceleration is change in speed over change in time:a = \frac{v - u}{T} \Rightarrow v = aT + u
Soooo... combining them:2d = \big ( (aT + u) + u\big )T = aT^2 +2uT \Rightarrow d = uT + \frac{1}{2}aT^2... which you will recognize as a kinematic equation.
... so what you've done is basically the same as assuming a constant acceleration, and is consistent with other physics you know.
