Fundamental Frequency of Two Pipe Organs
Two organ pipes, each 1.18 m long and open at one end, were analyzed for their fundamental frequencies. The first pipe's frequency was calculated to be approximately 72.67 Hz, while the second pipe, lengthened by 2.50 cm, had a frequency of about 71.16 Hz. The beat frequency produced when both pipes are played together was determined to be 1.51 Hz. The discussion highlighted the importance of correctly applying the formula for beat frequency and acknowledged that the problem statement was incomplete. Ultimately, the calculations confirmed the expected results for the frequencies and beat frequency.
Northbysouth
Two organ pipes, open at one end but closed at the other, are each 1.18 m long. One is now lengthened by 2.50 cm
λ = nL/4
fn = nv/4L
v = λF
Here's what I tried
First I tried finding the fundamental frequency when their lengths were equal
f = (1)(343 m/s)/4(1.18m)
f = 72.66949153 Hz
I'm assuming that v = 343 m/s. It does not say that this is the case in the problem.
Then I tried finding the frequency of the pipe with the extension
fextended = (1)(343 m/s)/4(1.205m)
fextended = 71.16182573 Hz
Having found these two frequencies I then took of the average of them which gave me 71.916 Hz. Unsurprisingly this didn't work. Any suggestions?
Pipe need not be resonating in the fundamental mode. So take lambda =(2n +1)L/4 and proceed.
If you still need help for this problem, try using this equation
fBeat = fa-fb
Solve for frequency using f=(nv)/(4L) where fa is the fundamental frequency for the pipe at its original length and fb is the fundamental frequency for the pipe when it is extended.
And v=344m/s (speed of sound in air)
Sorry it's been so long since I've replied, its been a busy week.
But yes you're right
f_beat = f_a - f_b
So I found that if I take f_a to be
f_a = (1)(343 m/s)/4(1.18m)
f_a = 72.66949153 Hz
Then the pipe with the increased length
f_b = (1)(343 m/s)/4(1.205 m)
f_b = 71.16182573 Hz
Then
f_beat = 72.66949153 Hz - 71.16182573 Hz
f_beat = 1.507 Hz
Rounded to 3 sig figs, 1.51 Hz is the correct answer.
The problem statement is not complete. What is required in the problem?
You're right, it is missing a part; I don't know how I managed that. Sorry to waste your time. The missing part is:
a) Find the frequency of the beat they produce when playing together in their fundamental.
