Fixed Mass of Viscous/Inviscid , Compressible/Incompressible Fluid
  • Thread starter Thread starter DabaDuBa
    Fluid Mass
The discussion focuses on the effects of falling fluid from a height, specifically comparing inviscid and viscous flows in terms of energy, momentum, and entropy. The initial confusion arises from the use of contradictory terms "inviscid/viscous." Participants clarify the need to analyze each fluid type separately at different phases: at the top of the dam, during the fall, at the drop point, and after the drop. Key considerations include how viscosity affects energy dissipation and momentum transfer, as well as changes in entropy throughout the process. Understanding these dynamics is crucial for fluid mechanics applications.
DabaDuBa
Hello there ,
could you please explain to me what would happen to an inviscid/viscous incompressible flow (energy,momentum and entropy wise)falling from a height ? ( i.e a dam )
Thanks;)
To be honest, I am not really sure what you are asking, especially since you say "invsicid/viscous", which are opposite terms.
I meant how would each of the mentioned values ( entropy , momentum , energy ) would change for both a viscous and an inviscid fluid for each phase : a ) at the top of the dam , b) while falling c) when it drops d) after the drop
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
