Equality of Operators A & B on Hilbert Space H
  • Thread starter Thread starter ShayanJ
    Operators
ShayanJ
Insights Author
Imagine we have two operators A and B on a complex hilbert space H such that:
<br /> [A,B] \psi = (AB-BA) \psi=c \psi \ \ \ \ \psi \epsilon H \mbox{ and } c \epsilon C<br />
Then can we say that [A,B] is the same as cI when I is the identity operator?Why?
Thanks
Let T,S<img src="/styles/physicsforums/xenforo/smilies/arghh.png" class="smilie" loading="lazy" alt=":H" title="Gah! :H" data-shortname=":H" />\rightarrow H (if you're working with unbounded operators then things change). By definition, we have
T=S
if and only if
T\psi = S\psi
for all \psi\in H.
So yes, in that case we can say [A,B]=cI.
So if we have unbounded operators,we should deal with the domains too?
Let D(I)=H and let one of A and B be unbounded.
What you tell now?
Thanks
@micromass: Shyan's questions are motivated by this thread, where there's some discussion about what's wrong with calculations like this one:
Fredrik said:
Suppose that [A,B]=cI, where I is the identity operator and c is a complex number.
\begin{align}1 =\frac 1 c \langle a| cI|a\rangle =\frac 1 c \langle a|[A,B]|a\rangle =\frac 1 c \big(\langle a|AB|a\rangle - \langle a|BA|a\rangle\big) =\frac 1 c\big(a^*\langle a|B|a\rangle-a\langle a|B|a\rangle\big)=0.
\end{align} I used that a is real in the last step.
I don't understand the issues well enough (or just haven't thought it through enough) to write down a complete explanation of everything that's going on here, but it's clear that it has something to do with the domains of the operators.
I see. But in that case, [A,B] is only densely defined. So
[A,B]\psi
doesn't even make sense for all \psi \in H.
And since I is everywhere defined, we can never have [A,B]=cI. We can only have [A,B]\subset cI.
Yes,But we can define an identity operator with the same domain as [A,B] and do the calculations.Or we can choose a vector from [A,B]'s domain.So what you say doesn't solve the problem.
P.S.
Ok guys,looks like here's going to be the same discussion as the topic related to that paradox,so I guess you guys may want to lock this one.
What problem??
It's probably not a good idea to have two threads on the same topic. So I'm going to lock this thread and ask that we discuss this further in the thread that Fredrik linked.
