Spherical Pendulum Motion: Solve the Mystery
  • Thread starter Thread starter praeclarum
    Pendulum Spherical
The discussion centers on the motion of a point mass constrained to move along the inside of a spherical pendulum. The original poster seeks a function to describe this motion, noting the forces of gravity and constraint acting on the mass. They mention attempting to use potential energy equations but feel stuck on how to proceed. Other participants suggest using conservation of angular momentum and energy principles to analyze the system. The conversation emphasizes the complexity of the motion compared to simpler pendulum models.
praeclarum
I thought of this question the other day, and I was unable to solve it. A Google search has not helped, so I thought I might post it here.
A point mass hangs from a rod of length "l" from the center of a pendulum. The only forces acting upon the point mass are the force of gravity and the force of constraint (keeping it distance "l" from the center). Is there a function that describes the motion of the point mass?
hi praeclarum! :wink:
do you mean two pendulums hinged together?
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
OK. It's not as complicated as a double pendulum. It's just a single pendulum where the mass is constrained to a sphere (rather than the 2-dimensional case where you have a circle).
Well, one thought I had was to solve for the potential energy of the system, since that's just
mgh+1/2mv^2 = C
The mass is just a constant, and we can get rid of it.
From this point, I am stuck, however, and I don't know where to go from here. I was thinking the initial velocity must be perpendicular to the force of constraint and was wondering if you could split up the motion into just x and y components to solve it, but that seemed fruitless upon inspection.
I am looking for a general function that describes the motion of the point around the sphere. Your help is appreciated greatly.
so it's basically a mass moving on the inside of a sphere?
hmm … in linear problems we usually use conservation of energy and conservation of momentum, sooo …
have you tried conservation of angular momentum ? :smile:
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
