If entropy is a state function, how can it keep on increasing?
Entropy is a state function, meaning its value depends only on the state of the system, not the path taken to reach that state. In an isolated system, a reversible process results in no change in entropy, while an irreversible process leads to an increase in entropy, indicating different final states. This implies that distinct states can be reached through reversible and irreversible processes, which can create confusion about the nature of state functions. The discussion clarifies that while a reversible process can lead to a specific state, an irreversible process cannot achieve that same state, reinforcing the unique outcomes of each process type. The conclusion drawn is that it is indeed impossible to reach the same state through an irreversible process as one would through a reversible one.
champu123
I just have this confusion which is completely eating me up. They say entropy of a system is a state property. Then they say that for a completely isolated system, entropy either increases or remains zero depending on the process being irreversible or reversible.
So, let's say for an isolated system I go from A to B thru a reversible path then entropy is zero. And if I go thru an irreversible path, it's something else. But if entropy is a state property, how can it be different for the two paths between same points? This completely makes no sense to me.
Likes Joker93
Science news on Phys.org
champu123;4224876 So said:
If entropy increases, the two paths will not link the same points. There is a set of points B which can be reached on reversible paths starting from A and there are other distinct states B' which can only be reached in irreversible processes.
Plot the state of the system using Entropy and Temperature as coordinates.
Thanks for the reply. That cleared up some confusion. I also found some long discussion here: https://www.physicsforums.com/showthread.php?t=313396. This thread poses the same question as my confusion.
Hence, I'd like to quote the above mentioned thread and answer the question posted in above thread based on my understanding. In the above thread, the user say:
If we consider an isolated system in which a process occurs, then according to the clausius inequality :
dS≥dQ/T
Since dQ = 0 , it follows that if the process occurs reversibly dS = 0 and irreversibly dS > 0. But entropy is a state function , how could this possibly be ?
My answer: The point here is that if the process occurs irreversibly it takes the system to a different state then when it'd have been reversible.
Now, if I say that the system is at state A, and perfectly isolated. Now, if there is a reversible process which takes it to state B. So, are you saying that it's impossible to design an irreversible process that can take the system to state B? By using an irreversible process, you could take it another state B' or B'' but not B. I think the answer should be yes (i.e. it'd be impossible). And in that case it's a very interesting conclusion.
So now tell me is the conclusion indeed true??
If you mean with perfectly isolated that the system is thermally isolated but can also not do any work (or that no work can be done on the system) then you are right, the state cannot change at all.
However, usually with isolated one understands only thermally isolated, so that work can still be done.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
