Mathematical proof for positive feedback
Positive feedback in operational amplifiers (op-amps) can lead to saturation, which is mathematically supported by the gain equation A = A0 / (1 + βA0). In this equation, a positive feedback factor (β) reduces the denominator, causing the gain to approach infinity as β nears 1. This results in the output voltage being driven to saturation, as even minor input changes yield significant output variations. The phenomenon demonstrates that with increasing feedback, the op-amp's gain decreases and can ultimately lead to saturation. Thus, the mathematical proof confirms that positive feedback drives op-amps into saturation.
anb2020
Is there a mathematical proof that the positive feedback makes the op-amp saturated?
http://i.imgur.com/71PNh.png
Do you understand why it saturates (non-mathematical seat of the pants explanation)?
Let's clarify this by specifying positive DC feedback drives the opamp into saturation. Positive AC feedback makes it oscillate.
Yes of course
There is indeed a mathematical proof that positive feedback can cause an operational amplifier (op-amp) to become saturated. This can be seen by analyzing the gain equation for an op-amp in a positive feedback configuration.
The gain equation for an op-amp in a closed loop configuration is given by A = A0 / (1 + βA0), where A0 is the open loop gain and β is the feedback factor. In a positive feedback configuration, the feedback factor is greater than 0, meaning that the denominator of the gain equation is less than 1.
When the feedback factor is small, the gain of the op-amp is approximately equal to the open loop gain A0. However, as the feedback factor increases, the gain decreases and eventually becomes 0 when the feedback factor is equal to 1. This means that the output voltage of the op-amp will be equal to the input voltage multiplied by the open loop gain A0, resulting in saturation.
Furthermore, the gain equation also shows that as the feedback factor approaches 1, the gain of the op-amp approaches infinity. This is known as the "infinite gain" phenomenon, where even a small change in the input voltage can cause a large change in the output voltage, leading to saturation.
In conclusion, the mathematical proof for positive feedback causing op-amp saturation lies in the gain equation, which shows that as the feedback factor increases, the gain decreases and eventually becomes 0, resulting in saturation.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
