Buy Alum Sulfate for 8000 Gal 48% Solution
  • Thread starter Thread starter obrien040362
To prepare 8,000 gallons of a 48% alum sulfate solution, first determine the density of the 48% solution. The weight of a gallon of water is multiplied by the specific gravity of the 48% alum sulfate to find the weight of one gallon of the solution. This weight is then multiplied by 0.48 and subsequently by 8,000 to calculate the required amount of anhydrous aluminum sulfate. If purchasing octadecahydrate, the calculated amount should be multiplied by the ratio of 666/342, and for hexadecahydrate, by the ratio of 648/342 to obtain the correct quantity needed.
obrien040362
How many pounds of alum sulfate do I need to buy to make 8000 gallons of 48% solution.
Thank you
Chemistry news on Phys.org
You do it the same way you did the 25% NaOH solution. You will need to determine the density of 48% alum sulfate first.
I did review that answer before I posted , but I don't know how to calculate the solution weight of 25% NaOh or 48% Aluminum Sulfate
Can you figure weight of solution with specific gravities?
Yes. Multiply the weight of a gallon of water by the specific gravity of your want to be alum solution to get the weight of a gallon of 48% w/w alum sulfate. Multiply that by. 48 and multiply that answer by 8000.
That's how much anhydrous aluminum sulfate you will need to use. If you are purchasing the octadecahydrate, multiply that number by the ratio (666/342). If purchasing the hexadecahydrate multiply it by the ratio (648/342).
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
