- 42,676
- 10,444
I would have thought that the chain/string could be arbitrarily thin. The thinner it is, the less it will matter if it's all piled up.ehild said:Any comment about my post#46?
ehild
ehild
If you lay it out straight, sure, but in the OP it was piled up, and as you make it progressively thinner that matters less and less.ehild said:It has constant length. It can not happen that the lifted part moves vertically upward and the horizontal part does not move at all. So the KE can not be calculated from u, the vertical component alone.
ehild
D H said:To see that it must be incorrect, simply reverse the process: Lower the chain rather than raising it. To keep the chain moving downward at a constant velocity we'll let connect the upper end of the chain to some physical device and let the lowering chain do work on that device. How much work is performed? If we attribute all of the change in momentum to work done by that the device we get an over unity system. More work will be performed than is allowed by the conservation laws. That doesn't make sense.
Why is momentum conserved? That implies no net force.haruspex said:... and which is wrong. The correct answer is achievable by consideration of conservation of momentum and can be done without involving the dp/dt formulation.
Or both.Conservation of momentum and conservation of work energy (as opposed to thermal energy) lead to different answers - one must be flawed.
No, it only requires that all forces have been taken into account. Using the work energy theorem requires all losses have been taken into account, and there's a good reason to suspect there are losses: an elastic string would have been accelerated on take up and overshot equilibrium, leading to oscillations. The energy that would have gone into these must have been dissipated somehow.tms said:Why is momentum conserved? That implies no net force.
But the problem involves idealized object, the way most intro physics problems do. There is no information about possible sources of energy loss. Since a supposed loss is calculated without such information, it implies that every situation involves the same loss. I find it very hard to believe that pulling up an anchor chain (with links 2 feet across) and pulling up a shoestring both create exactly the same loss.haruspex said:No, it only requires that all forces have been taken into account. Using the work energy theorem requires all losses have been taken into account, and there's a good reason to suspect there are losses: an elastic string would have been accelerated on take up and overshot equilibrium, leading to oscillations. The energy that would have gone into these must have been dissipated somehow.
tms said:But the problem involves idealized object, the way most intro physics problems do. There is no information about possible sources of energy loss. Since a supposed loss is calculated without such information, it implies that every situation involves the same loss. I find it very hard to believe that pulling up an anchor chain (with links 2 feet across) and pulling up a shoestring both create exactly the same loss.
Using F = dp/dt, on the other hand, presupposes only that you know the change in momentum in order to get the net force, and I don't see how that could be wrong.
Thanks Dick, well put.Dick said:I think haruspex would agree that F=dp/dt is the right thing to do, and would also agree the loss doesn't depend on the detailed dynamics of how the energy was lost. Was just saying you can infer by thinking about possible ways the loss can occur that you can conclude it must happen. You don't disagree. DH is the one who disagrees.
The mechanism of the loss may be rather different; I picture the anchor chain links as swinging side to side briefly as they leave the ground, rather than bouncing up and down. But it would appear that about half the energy is lost either way.tms said:I find it very hard to believe that pulling up an anchor chain (with links 2 feet across) and pulling up a shoestring both create exactly the same loss.
tms said:I just think we're missing something---I don't know what.
It's as if we were doing a typical block-on-frictionless-surface type problem, and the answer had a frictional loss in it---a frictional loss that was the same for every block and surface.
I don't see any difficulty. Try this analogy. A chain of buckets (ideally, flat platforms) moves up past a fixed platform at (on average) constant speed u. An operator slides masses m from the fixed platform onto the moving ones as they go past. (These masses stand for bits of string/chain.) Clearly, each such move is an impact. If the total mass of the chain and its existing masses is M then each impulse costs it speed um/M, and the energy needed to restore its speed is M(u2-(u-um/M)2)/2 = mu2(1 - m/M). As m/M→0, that's mu2, double the kinetic energy imparted to the mass m.tms said:I just think we're missing something---I don't know what.
Do it right and they don't disagree.haruspex said:... and which is wrong. The correct answer is achievable by consideration of conservation of momentum and can be done without involving the dp/dt formulation. Conservation of momentum and conservation of work energy (as opposed to thermal energy) lead to different answers - one must be flawed.
D H said:Do it right and they don't disagree.
That's wrong. If links magically attach themselves to the chain with the same velocity as the chain itself, the lifter only needs to support the weight of the chain, so F=ρgx. There is no u term with this style of magic.Dick said:One more time. Here's a work-energy picture. Suppose the length of the chain is L. Just so I don't have to worry about inelastic stuff, I'll put a machine on the platform that accelerates each link of the chain to velocity u before it gently attaches it to the rising chain. So when the chain clears the deck it has PE (1/2)L^2ρg and KE (1/2)Lρu^2 and the force on the chain was just as you say.
D H said:That's wrong. If links magically attach themselves to the chain with the same velocity as the chain itself, the lifter only needs to support the weight of the chain, so F=ρgx. There is no u term with this style of magic.
It's best not to do physics in a world where magic occurs, but if you insist on doing so, you at least should get the mathematics right.
D H said:sankalpmittal, the correct answer is not (D), F=ρ(u^2-gx). It makes no sense. Force decreases with increasing height? The force obviously must increase as x increases.
In your model, where you lift each link up by one end until vertical, the acquired velocity of the link, at the point where it reaches vertical, has become horizontal.D H said:Next let's look at what happens during the process of lifting a single link of the chain off the platform. Between the point in time when the link is lying flat on the platform and the point in time when the link is vertical and lifts off the platform, the lifter only applies a force equal to half of the link's weight. The platform bears the other half of the link's weight1[/color]. It's only until the link is vertical and lifted off the platform that the lifter bears the entire weight of the link. By this time, the link has already been accelerated to an upward velocity of u.
Eh? So if I hesitate with a link part lifted I get extra momentum from the platform?! None of this discussion needs to involve gravity. The same problem can be posed in free fall. Hence we can safely ignore any force from the platform.Use conservation of momentum with the platform bearing half the weight during the process of lifting a single link and you'll get a force equal to ρgx+½ρu2.
If you mean in the sense of matter being created with zero velocity in the reference frame, I have not used that in any of my posts. I agree it's wrong.Finally, let's look at what happens if we use F=dp/dt.
sankalpmittal said:Thanks for your reply. My thinking in that was: When chain was pulled to a height x by a variable force "F" , then only the lower part receive normal reaction. Still most of its part was in air (consider vacuum). Thus the net force according to me should be F-ρgx and F can be evaluated. Using the answer (D), I could justify work energy theorem (post 21). How? I am confused.![]()
Look at the problem in parts. The lifter is bearing the weight of the chain that is already lifted off the platform and is applying a force to lift even more of the chain off the platform. Both of those forces point upwards when the chain is being lifted upwards. Answer D makes no sense.sankalpmittal said:Any comments regarding my post #71 ?
Why? What justifies that opinion?BTW, I am also of the opinion that force from the platform on chain can be ignored.
I think it's just a bad problem. You get a consistent answer, one not listed, if you use work energy concepts, a Lagrangian formulation, or a Hamiltonian formulation. You get a different answer if you ignore that the platform is somehow of assistance.haruspex said:All that said, I think I see why it's such a divisive issue.
D H said:You get a different answer if you ignore that the platform is somehow of assistance.
The real answer? You'd have to have a very detailed model of the elasticity/inelasticity of the chain, detailed models of the transients as parts of the chain are lifted off the platform, etc. A freshman physics problem should not require finite element analysis to get the right answer.
Agreed. As I keep suggesting, we can get rid of this 'contribution from the platform' furphy by casting it in a free fall context. We can also get rid of any orthogonal movement by taking the chain/string/plates to be exceedingly thin. E.g. it could be a tiny coil of string around the axis of movement. The hard part, for the imagination, is to understand that:Dick said:You really have to attribute the rest to some contribution from the platform. It has to somehow push the chain up with more than normal forces. I think this is what BruceW is talking about when he is saying there is a nonzero tension at the bottom of the chain. I don't think that's a very reasonable thing.
The point I was making is that simple mechanics tells us the behaviour of the chain above the ground level, even if the behaviour at ground level is more complicated. To show this, here is the equation for balance of momentum in the suspended part of the chain:Dick said:You really have to attribute the rest to some contribution from the platform. It has to somehow push the chain up with more than normal forces. I think this is what BruceW is talking about when he is saying there is a nonzero tension at the bottom of the chain. I don't think that's a very reasonable thing.
