Activation energy/bond enthelpy
  • Thread starter Thread starter GeneralOJB
    Activation
Activation energy is defined as the minimum energy needed for a chemical reaction to occur, primarily associated with breaking original bonds. It is not solely the energy required to break bonds but also includes the energy needed to overcome the energy barrier for the reaction to proceed. The activation energy for forming a bond is not the same as the bond enthalpy for breaking that bond; they represent different concepts in thermodynamics. For further clarification, consulting the Wikipedia article on activation energy can provide additional insights into these topics.
GeneralOJB
I'm doing A level Chemistry, and my teacher isn't good at explaining things. I know activation energy is the minimum energy required for a reaction to take place - so is that just the energy required to break the original bonds? And is the activation energy for a particular bond to form the same as the bond enthalpy (to break the bond)?
Chemistry news on Phys.org
Have you checked the wikipedia article on the activation energy? I think it addresses both your questions.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
