Express the density of a solid substance varying with temperature
The density of a solid substance can be expressed as d = d0(1 - 3aT), where d0 is the initial density, a is the thermal coefficient, and T is the temperature change. The volume of the substance changes according to V = V0(1 + 3aT), with mass (m) remaining constant. The relationship indicates that as temperature increases, density decreases due to the expansion of the material. The discussion also suggests assuming that the change in density (d - d0) is negligible for small values of a, allowing for simplification using the binomial theorem. This leads to the conclusion that density varies linearly with temperature changes in the specified form.
endeavor
I need to show that the density of a solid substance varies with temperature as d = d0(1 - 3aT), where a is the thermal coefficient and T is the change in temperature.
I know V = V0 (1 + 3aT) and V = m/d. Since m is constant,
d0 = d(1 + 3aT)
d0 - d03aT = d + d3aT - d03aT
d0(1 - 3aT) = d +3aT(d - d0)
Am I now supposed to assume that the d only changes a little compared to d0, so that (d - d0) = 0?
do = d(1 + 3aT)
d = do/(1+3aT) = do(1+3aT)^-1
now expanding using binomial theorem and as a is very small the higher terms can be neglected, gives
d = do(1- 3aT + ...)
MP
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
