What are the limitations of treasure hunting metal detectors?
  • Thread starter Thread starter wolram
Treasure hunting metal detectors face limitations in discriminating between ferrous and non-ferrous objects, as well as ground minerals. The effectiveness of these machines largely depends on their field strength and frequency settings. Higher frequencies can improve sensitivity to small objects, while lower frequencies may better penetrate mineralized soils. The design and technology of the detector play crucial roles in its performance. Understanding these factors is essential for optimizing treasure hunting efforts.
wolram
Dearly Missed
This is a tresure hunting MD, the design needs a way of discriminating from ferrous, none ferrous objects, and minerals in the ground, what are the limits
of such a machine ?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
