pardesi
- 337
- 0
how does an electron 'flow' in a circuit ...can someone please explain me the detailled mechanism ...
pardesi said:can't it be more detailled?as to how when connected toa battery the electrons start flowing?
What happens is that as soon as you hook up the wire to the battery, electrons move onto the surface of the wire at one end (and off of the wire surface at the other end), just as they would on any conducting surface. A small charge gradient is quickly built up along the surface of the wire, which creates the electric field within the wire that drives the current.pardesi said:well i still don't get it why do the elctrons ever move insid ethe wire..if it is due to the field due to battery or any other source then that should depend on orientataion of wire...so what actually does make the electron move
Doc Al said:What happens is that as soon as you hook up the wire to the battery, electrons move onto the surface of the wire at one end (and off of the wire surface at the other end), just as they would on any conducting surface. A small charge gradient is quickly built up along the surface of the wire, which creates the electric field within the wire that drives the current.
Yes, this redistribution of charge takes place very quickly. Realize that charges don't need to travel the length of the wire, they just have to shift a bit to create the electric field.Emanresu said:Doc Al, I always thought that the field in a circuit propogated at c such that a bulb many kilometers away from a switch would turn on almost instantly. Can the gradient you talk about really propogate that fast ?
