Rewriting iterated triple integrals
blitzme
[SOLVED] Rewriting iterated triple integrals
Rewrite this integral as an equivalent iterated integral in the five other orders.
\int_{0}^{1}\int_{\sqrt{x}}^{1}\int_{0}^{1-y}f(x,y,z) dz dy dx
Ok, so I have the shape drawn out.
The projection on the XY-axis is the region bounded by half the parabola y=\sqrt{x} and the line y=1.
So, 0 \leq x \leq y^{2}, 0 \leq y \leq 1
Or 0 \leq x \leq 1, \sqrt{x} \leq y \leq 1
The projection on the YZ-axis is the triangle bounded by z=0 and the line z=1-y.
So, 0 \leq y \leq 1-z, 0 \leq z \leq 1
Or 0 \leq y \leq 1, 0 \leq z \leq 1-y
The projection on the XZ-axis is another triangle, bounded by z=0 and the line z=1-x
So 0 \leq x \leq 1-z, 0 \leq z \leq 1-x
Or 0 \leq x \leq 1, 0 \leq z \leq 1
When I use those to make my integrals, I get
1) \int_{0}^{1}\int_{0}^{\sqrt{y^{2}}}\int_{0}^{1-x}f(x,y,z) dz dx dy
2) \int_{0}^{1}\int_{0}^{1-x}\int_{0}^{1-z}f(x,y,z) dy dz dx
3) \int_{0}^{1}\int_{0}^{1-z}\int_{\sqrt{x}}^{1}f(x,y,z) dy dx dz
4) \int_{0}^{1}\int_{0}^{1-y}\int_{0}^{1-z}f(x,y,z) dx dz dy
5) \int_{0}^{1}\int_{0}^{1-z}\int_{0}^{y^{2}}f(x,y,z) dx dy dz
I substituted 1 for f(x,y,z) and evaluated the integrals. Number 5 was the only one that was equal to the original (1/12).
What did I do wrong? I would really appreciate your help, thanks.
Since the first integral is still with respect to z, you can use exactly the same limits of integration on that integral: 0 to 10- y. Of course, switching x and y, you switch y= \sqrt{x} to x= y^2. I assume \sqrt{y^2} was a typo.
\int_{y=0}^{1}\int_{x=0}^{y^2}\int_{0}^{1-y}f(x,y,z) dz dx dy
Did you notice that the information that y= \sqrt{x} is a boundary has completely disappeared here? Now that can't be right!
You know that z ranges, for fixed y, from 0 up to 1- y. You also know that y can range from 0 up to \sqrt{x}. That is, z can range, for fixed x, from 0 up to 1-\sqrt{x}. Then y can range from 0 up to 1-z.
\int_{0}^{1}\int_{0}^{1-\sqrt{x}}\int_{0}^{1-z}f(x,y,z) dy dz dx
Just as z did not range from 0 up to 1- x, so x does not range from 0 up to 1- z. x could range from 0 up to y^2 and y can range from 0 up to 1-z: x ranges from up to (1- z)^2.
\int_{0}^{1}\int_{0}^{(1-z)^2}\int_{\sqrt{x}}^{1}f(x,y,z) dy dx dz
Same point as in 2 and 3: x ranges from 0 up to (1-z)^2
\int_{0}^{1}\int_{0}^{1-y}\int_{0}^{(1-z)^2}f(x,y,z) dx dz dy
First of all, I just want to say thank you, and I appreciate your help.
Yes, \sqrt{y^2} was a typo, and I understand what you did with this one. Also, when I evaluate the integral by plugging in for f(x,y,z) I get the same value as my original answer.
However, for these integrals I get a different answer from my original when I plug in the same f(x,y,z). I understand that I need to have the x=y^{2} bound in there in some form, but those integrals don't seem to work out when I check them. That's a valid way of checking the integrals, right? No matter how you write an iterated integral, it should yield the same result for each f(x,y,z).
It wouldn't surprise me if I'm just doing something wrong, but I don't see what.
I think I follow what you did, but are you sure your integrals are right?
Again, thank you for your help!
I've found the correct answer.
should be
\int_{0}^{1}\int_{0}^{1-\sqrt{x}}\int_{\sqrt{x}}^{1-z}f(x,y,z) dy dz dx
should be
\int_{0}^{1}\int_{0}^{(1-z)^2}\int_{\sqrt{x}}^{1-z}f(x,y,z) dy dx dz
and
should be
\int_{0}^{1}\int_{0}^{1-y}\int_{0}^{y^2}f(x,y,z) dx dz dy
Thanks for helping me out!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
