Find equation of path of a point mass under influence of 2 central forces
A point mass A is located at the origin, while point masses B and C are positioned along the x-axis, forming an isosceles triangle with A. The discussion focuses on deriving the equation of motion for mass C, influenced by both A and B, under Newton’s gravitational law. C and B start with zero initial velocities, leading to a complex interaction due to their relative masses. Participants are encouraged to share their attempts and clarify their equations, particularly regarding the measurement of angles and the inclusion of constants in their formulas. The conversation emphasizes the need for proper LaTeX formatting for mathematical expressions in the forum.
taureau20
A point mass ‘A’ is kept at the origin. Another B is kept at the x-axis at x = H. Another C is kept at distance H from origin and distance h from B. A, B and C thus form an isosceles triangle with vertex A. Given that A's mass >> B's mass >> C's mass; Newton’s gravitational law governs the bodies. C will have motion because of both A and B while B will have motion because of A only.
Find:
The equation of path of C in any coordinate system given that B and C have zero initial velocities.
Welcome to PF!
Hi taureau20! Welcome to PF! :smile:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
tell me within what tags must I enclose the LATEX code so I can post mathematuical expressions here. I can't do that here. Plz help w.r.t. that.
anyway, you may click http://www.physicshelpforum.com/phy...urce-one-stationary-one-moving.html#post1534"; in this site, the LATEX coding has worked so I have posted my attempt at solving this problem.
You can take it from there!
Thanks!
Thanks!
Hi taureau20! :smile:
sorry, but I can't follow your equations (3) and (4) :confused:
is theta measured from B or from C?
why is there no ka in (3)?
Can you check it, and type it out again, here … for LaTeX in this forum, just type [noparse]before and after.[/noparse] :smile:
