Flow through Convergent-Divergent Duct
  • Thread starter Thread starter neostalker
    Flow
The discussion focuses on the behavior of flow through a convergent-divergent duct, emphasizing that in horizontal flow with incompressible fluids, pressure head decreases due to frictional losses, resulting in actual total pressure head being less than the ideal. When the duct is inclined upward, the pressure head increases upstream, but total head loss remains constant until the pressure head equals the elevation head downstream, causing the fluid to come to rest. The conversation also explores the implications of compressible fluids on pressure loss, prompting further inquiry into how these factors affect flow dynamics. Additionally, the angle between the convergent and divergent sections in pressure relief valves is questioned for its impact on nozzle behavior. Overall, the discussion highlights key principles of fluid dynamics in convergent-divergent ducts and their practical applications.
neostalker
Guys, i would like to ask some opinion from u all. About the convergent-divergent duct, it is horizontal flow and the water is incompressible.
So, based on Bernoulli's equations, elevation and density is the same. Because of the frictional losses, the actual total pressure head, H is less than then the Ideal Pressure Head.
Any disagreement from you guys, or any other opinion.
If the convergent-divergent duct is inclined upward, what will happen?
If the duct was inclined upwards the pressure head will increase at the upstream due to difference in height , but the total head loss will stay constant .
The flow will continue until the pressure head at upstream equals the elevation head at downstream thus velocity head will be zero and the fluid comes to rest.
Guys,
Following the quesrtion by neostalker, I would like to know what would happen if the flow is with compressible fluids ? What will be pressure loss in this case ?
johntyroger said:
Guys,
Given the generality of your question, here is a good point to start reading:
http://www.engapplets.vt.edu/fluids/CDnozzle/cdinfo.html
CS
CS
Thanks for the response Stewart CS. The link was very helpful.
It was a very good start for me. In the case of the pressure relief valves, usually the convergent and divergent sections of the nozzle are perpendicular to each other. Is this angle between going to affect the behaviour of CD nozzle ?
With relief valves you'll have a coefficient of discharge from the manufacturer to account for the flow through the valve. The rule of thumb is 0.975 if I recall correctly (per ASME and API). However, the manufacturer should provide it to you. A good reference is API 520 and ASME BPV Code.
CS
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
