RestlessMind
- 173
- 0
Does anybody happen to know what it is, or how to find out the voltage drop of a particular transistor?
Draven said:Does anybody happen to know what it is, or how to find out the voltage drop of a particular transistor?
Draven said:Here's the datasheet: http://www.fairchildsemi.com/ds/2N/2N3904.pdf
And it will be used to switch on an LED; the battery is 3.6V, 600mAh.
waht said:In this circuit the transistor is in saturation mode. If you turn it on at the base the collector voltage will be close to zero, and so you can treat the collector as a ground for most purposes. If off, the collector will remain open and no current will flow.
Draven said:Well, I'm a bit of a novice, but I know that there is a voltage drop when the current passes through the collector/emitter, so that if you send, for example, 10V through you might only get something like 9.5V of of the other side. So I want to know how to find out that voltage drop for a specific model of transistor, such as the 3904.
Are you saying that the 3904 requires a volt to the base to fully turn on?This is a clip from a 2N3904 data sheet.
Note the marked values for Vce and also the very low gain of the transistor at saturation.
Ic is only 10 times Ib.
Also in the next line, see the base voltage at saturation. Nearly a volt.
I... think I sort of get this. A beta of 100 means that emitter:collector is 1:100?You should think in terms of current when working with transistors. Get yourself familiar with the definition of beta. Beta is the ratio of emitter current to base current. With a typical beta of 100 we usually, for simplicities sake, assume the collector current and emitter current are the same. Suppose you have a load in series with the collector that draws 50 mA when 5 volts is across it (100 ohm resistor).
That's where you really lost me. Didn't you say that the load was 5V, and now its .2V? I'm confused. And not really sure how this applies to my problem.Suppose the transistor you have picked has a beta of 100. So in order to get the complete (or very close within .2 volts) supply voltage across the 100 ohm resistor you need to supply a current that is .05/100 (collector current/beta) into the base, or .5 mA. At this point, the transistor is said to be saturated. Any more current we put into the base will not cause any more current to flow in the collector circuit. However, if we decrease the 100 ohm resistor to 75 ohms, then it will take more base current to get the full 5 volts across the 75 ohm resistor. Work with currents when dealing with transistor circuits.
