Integral Involving Trigonometric Functions with Varying Arguments
Joshk80k
I'm in an Intermediate Mechanics course right now, and while the Physics itself isn't giving me too much trouble, I am lagging behind in the Math department. I am trying to solve the integral:
\int cos(\omega t) sin(\omega t - \delta) dt
sin(A-B) = sin(A)cos(B) - sin(B)cos(A)
The first thing I recognized is that the trig functions had the same argument, plus a value, so I figured I could apply the above equation to the integral. However, that really just made things look more complicated.
\int cos(\omega t)sin(\omega t)cos(\delta) -sin(\delta)cos^2(\omega t) dt
I stared at this for a while, but I couldn't find any substitutions (Which is what I was expecting.) I then thought that maybe I should try an integral table, to see if this was listed somewhere, but I couldn't find any functions that might have made sense. The added value in the argument of the "Sin" function is what's tripping me up.
Can anyone give me a push in the right direction?
sin(wt)cos(wt) is easy enough to integrate; just use u=sin(wt). For cos^2(wt), the standard way of integrating this is to use the identity cos(2x)=2cos^2(x) - 1.
Looks good so far, now just split the integral into two and pull the constants out front:
\int \left[\cos(\omega t)\sin(\omega t)\cos(\delta) -\sin(\delta)\cos^2(\omega t)\right]dt= \cos(\delta)\int\sin(\omega t)\cos(\omega t)dt-\sin\delta\int\cos^2(\omega t)dt
The first integral can be easily done by substituting u=\sin(\omega t) the second integral can be evaluated by using another trigonometric identity, \cos^2(x)=\frac{1}{2}\left(\cos(2x)+1\right)
So I am able to rewrite
\int cos(\omega t)sin(\omega t)cos(\\delta) -sin(\delta)cos^2(\omega t) dt
as
\int cos(\omega t)sin(\omega t)cos(\\delta)dt - \int sin(\delta)cos^2(\omega t) dt
I guess that does make it really easy - thanks =)
Sorry for the redundant information - I posted at nearly the same time as you did.
Thanks very much for your help =).
as
Sure, one of the fundamental rules of calculus is that \int\left[f(x)+g(x)\right]dx=\int f(x)dx+\int g(x)dx.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
