What's the truth about phase velocity vs. group velocity?
Phase velocity refers to the speed at which a peak or trough of a wave travels, while group velocity is the speed at which a group of waves or the overall energy of the wave packet propagates. Both phase and group velocities can exceed the speed of light (C) under specific conditions, such as anomalous dispersion, but neither represents the actual signal velocity, which remains below C. The discussion highlights that group velocity is typically a better measure for how information and energy propagate, especially when a well-defined wave envelope exists. An analogy is provided, comparing the scenario to lamps turning on in sequence to create the illusion of a light flash moving faster than C, illustrating that this does not equate to a physical signal traveling at that speed. Understanding these distinctions is crucial for interpreting wave behavior in optics.
peter.ell
I know the phase vs group question has been asked before, but I really don't quite understand it. I've read in various places that the phase velocity of a light wave has been made to go faster than C, and in others that the group velocity has been made to go faster than C, and even made negative so that it appears to exit a medium before it even enters. This is called anomalous dispersion, but what in the world does this mean?
What, conceptually, is the difference between phase velocity and group velocity, which is the one that can really go faster than C, and how can it do so?
Refer to this for the source of my questions: http://en.wikipedia.org/wiki/Dispersion_(optics)#Group_and_phase_velocity
Thank you so much!
Here's an applet that shows an example of group velocity greater than phase velocity.
http://gregegan.customer.netspace.net.au/APPLETS/20/20.html
This is actually rather unusual, and occurs under the conditions described on that page. Usually the group velocity is less than the phase velocity.
Perhaps someone can tell the original poster the conditions for which the signal velocity (which must be less than c) is approximately equal to the phase velocity or to the group velocity or to neither.
I believe that, most of the time, if there is a fairly well-defined envelope for a wave, the group velocity is a good description of how fast information and energy propagates. And that the phase velocity should almost never be used as a signal velocity. Someone correct me if I am wrong.
Simplistically speaking, phase velocity is the velocity at which a peak (or a trough) moves; group velocity is the velocity at which an entire group of waves moves.
Both. Neither one nor the other can represent the "signal velocity", excepting for special situations.
I will use a metaphor: if you put many lamps in a row and you make them switch on in a specific temporal order, you can make a flash of light move along the row at the speed you want, even > c. But this doesn't correspond to a physical signal moving along the lamps, because the lamps were programmed to switch on at the specified timing.
You can do the same with phase velocity and with group velocity (as in the nice applet posted by jtbell).
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
